Flash Point of Petrol & Diesel: Pressure & Self Ignition
In summary, the flash point temperature of petrol is lesser than that of diesel at the same pressure. Does this mean, if I take petrol and diesel as liquids in separate containers and heat them, rapid vapourisation (rapid enough to sustain a combustion) of petrol occurs at a lower temperature(fire point) than that of diesel? But if I take petrol and diesel as vapours and heat them, will diesel self ignite at a lower change in temperature(lower increase in temperature) than petrol?
Mohankpvk
102
Flash point temperature of petrol is lesser than that of diesel at the same pressure.
But if I take petrol and diesel as vapours and heat them ,will diesel self ignite at a lower change in temperature(lower increase in temperature) than petrol?
Are boiling point temperature,fir point and flash point temperature same at constant pressure(because,once vapourisation starts at constant pressure,the temperature doesnot increase till all the liquid vapourises)?
At higher pressures,a higher temperature is needed to vapourise the liquid.In engines, during compression, pressure increases.Does this mean the flash point at atmospheric pressure is lower than the flash point at the presaures inside an engine?
Does self ignition temperature depend on pressure?
In wikipedia it is mentioned that self ignition temperature decreases with pressure or oxygen concentration.Does this mean if we compress a fuel at constant temperature,it can self ignite at room temperature?
If you guys are hesitating to answer this question because of its length( six questions), it would help me a lot if you answer at least the following question.
Example:Heating diesel in an open container(at constant atmospheric pressure).
Mohankpvk said:
least the following question. Are boiling point temperature,fir point and flash point temperature same at constant pressure
No.
Likes Mohankpvk
Bystander said:
No.
But,how?During vaporisation,if the temperature of the liquid remains constant(constant pressure line in the saturation region), how will the three temperatures be different.
Thread closed for Moderation...
Thread re-opened. @Mohankpvk -- please do not cross-post you question in multiple PF forums. Thank you.
Likes Mohankpvk
Try googling "petrol, diesel, and flash point." The first two are "mixtures," many components, and the third is an awkward means/method of "quantifying" fire hazard(s).
Likes Mohankpvk
Bystander said:
The first two are "mixtures," many components.
Does this mean,for diesel and petrol,temperature changes during phase change(since they are mixtures)?
But flash point is well below the boiling point for diesel and petrol.So how does vapourisation occurs below the boiling point?
Yeah, in mixtures Temperature changes during a phase change
Likes Mohankpvk
Water boiling point at atmospheric pressure is 100 *C, but if you leave an open glass of water on a table for a sufficient amount of time you won't see the water anymore inside the glass... Where did it go? Ever thought about that?
Likes Mohankpvk
Google "vapor pressure, partial pressure(s)."
Likes Mohankpvk and berkeman
Vapourisation occurs at temperatures below the BP. It's just that at the BP temperature, the vapour pressure equals atmospheric pressure. Below BP temp, the liquids still evaporate, but have a lower saturated vapour pressure.
Likes Mohankpvk
When I googled it, I understood that vapourisation occurs even below the boiling point.It was explained that the molecules near the surface of the liquid(on the air surface interface),if they gain enough energy they break the liquid attraction force and escape into the surrounding.But this rate of vapourisation is very low(compared with after boiling point).As temperature increases, vapour pressure also increases.So a higher pressure is needed to keep the substance in liquid state.But since the external presaure remains constant,the evapouration rate increases.(these with higher vapour pressure at room temperature are called volatile)
Is this the right interpretation or is there any thing more to it?
Thank you guys.
On the internet, I read that the self ignition temperatures of petrol and diesel are arround 260 and 210 degree celsius respectively.The difference is just about 70degree celsius.The temperature at the end of compression in a CI engine is about(500 to600 degre celsius).
Then why can't diesel engine self ignite petrol.?
In a lot of websites,they claim that since petrol doesnot self ignite easily it cannot be used as a fuel for diesel engine.
Otto cycle was invented first and then diesel cycle was developed.So gasoline engines existed befor the diesel engines.
But there should be some other reason they switched the fuel oil for.Is self ignition the only reason or is there any other reason?
Gasoline self ignites just fine in a high compression diesel engine, way too quickly in fact, violently. "does not self ignite easily" makes no sense, maybe it means it is uncontrollable?
There are new gasoline engines working on using controlled autoignition google this "Controlled Auto-Ignition/HCCI Combustion."
Likes Mohankpvk
Thank you for answering.
Can this violent ignition of petrol be a reason for changing the fuel oil when diesel engine was invented?
Because the pressure at the end of compression will be significantly higher in a CI engine.Rapid combustion of petrol may add heat at constant volume(approximately) which will resul in ver high pressures.So diesel(which burns slowly) may be used(so that heat is added approximately at constaant pressure)
Can this be a reason?
There are probably lots of reasons why. Off the top of my head, higher efficiency due to higher compression, lower pumping losses due to no throttle in intake, diesel is safer and easier to store. I am no engine expert, just an ME who likes engines.
Likes Mohankpvk
Related to Flash Point of Petrol & Diesel: Pressure & Self Ignition
What is the flash point of petrol and diesel?
The flash point of petrol is typically between -43°C to -48°C, while the flash point of diesel is typically between 52°C to 96°C.
How does pressure affect the flash point of petrol and diesel?
As pressure increases, the flash point of petrol and diesel also increases. This is because the increased pressure prevents the vapors from escaping, making it more difficult for them to ignite.
What is the self-ignition temperature of petrol and diesel?
The self-ignition temperature of petrol is typically between 246°C to 280°C, while the self-ignition temperature of diesel is typically between 210°C to 260°C.
What factors can affect the flash point of petrol and diesel?
The flash point of petrol and diesel can be affected by various factors such as temperature, pressure, and the presence of impurities or additives. Higher temperatures and pressures can increase the flash point, while impurities or additives can lower the flash point.
Why is knowing the flash point of petrol and diesel important?
Knowing the flash point of petrol and diesel is important for safety reasons. It helps determine the potential fire hazards and safety measures that need to be taken during storage, transportation, and handling of these fuels. It also provides information about the quality and purity of the fuel.
  • Mechanical Engineering
20K
9K
  • Classical Physics
  • Classical Physics
