Fleury's Algorithm: Finding Next Edge
  • MHB
  • Thread starter Joystar77
  • Tags
    Algorithm
In summary, Fleury's Algorithm is a graph traversal algorithm used to find the next edge in an Eulerian path or circuit. It works by starting at a given vertex and traversing to a neighboring vertex, removing the edge that was traversed. An Eulerian path is a path in a graph that visits every edge exactly once, while an Eulerian circuit is a path that starts and ends at the same vertex, visiting every edge exactly once. Fleury's Algorithm is commonly used to find paths or circuits that visit every edge in a graph exactly once, such as in the Seven Bridges of Königsberg problem. Its advantages include simplicity and efficiency, but it can only be used on undirected graphs and may get stuck in a loop
Joystar77
125
Using Fleury’s Algorithm in the graph to the bottom left, I deleted three edges and I got the graph to the bottom right. If I am currently at the starred vertex, list all possibilities for the edge I should travel next.
A B Left graph
C D
1E F
A
B
Right graph
C D
E F
You did not include pictures of the graph. Also, the letters (A, B, E, F, etc.) that follow the first paragraph don't make sense without a context.
FAQ: Fleury's Algorithm: Finding Next Edge
1. What is Fleury's Algorithm and what is its purpose?
Fleury's Algorithm is a graph traversal algorithm used to find the next edge in an Eulerian path or circuit. Its purpose is to find the next edge that can be traversed without repeating any edges in a graph.
2. How does Fleury's Algorithm work?
Fleury's Algorithm works by starting at a given vertex and traversing to a neighboring vertex, removing the edge that was traversed. It continues this process until all edges have been traversed, creating an Eulerian path or circuit.
3. What is an Eulerian path and circuit?
4. When is Fleury's Algorithm used?
Fleury's Algorithm is used when trying to find a path or circuit that visits every edge in a graph exactly once, such as in the Seven Bridges of Königsberg problem.
5. What are the advantages and disadvantages of Fleury's Algorithm?
The advantages of Fleury's Algorithm include its simplicity and efficiency for finding Eulerian paths and circuits. However, it can only be used on undirected graphs and can get stuck in a loop if there are multiple possible paths to take at a given vertex.
