Floating potential of a conductor in an electrical field
In summary, the conversation discusses a scenario where a conductive plate at a known potential V is placed in the y-z plane and a conductive material M with neutral global electrical charge is placed at a distance from the plate. It is assumed that the distance between M and the plate is much smaller than the distance between M and anything connected to the Earth. The question is then posed about the potential of M with respect to the Earth, assuming it is a copper cylindrical rod of length 1 located from x = 1 to x = 2. It is noted that the potential of M will be constant and slightly lower than V, depending on the ratio of the distances between M and the plate and M and the Earth. The potential can be
coquelicot
299
67
I'm interested in the following general question: Assume x,y,z is an axes system, and that the y-z plane is occupied by a conductive plate at a known potential V with respect to the earth. Now, a conductive material M of neutral global electrical charge is placed at some distance of the plate, and is not connected to anything else. Furthermore, the distance of M to the plate is much smaller than the distance of M to anything connected to the Earth (so that, the direct influence of the Earth on M can be neglected). What is the potential of M with respect to the Earth ?
For the sake of simplicity, it can be assumed that M is a copper cylindrical rod of length 1 along the x axis, located from x = 1 to x = 2. Regarding the unspecified parameters, any assumption can be done.
Also, if the "infinite plate" is problematic, it can be assumed it's a large disk or a large rectangular plate.
Because M is conductive, the potential will be constant. Assuming that M is absolutely neutral (wrt. charge) and much closer to the plate at the potential V than ground, it will be at the potential just a bit lower than V. The exact potential would depend on the ratio of effective distances of the M to the plate and ground.
Thank you. Yes I know that but the question is: Neglecting the effect of the ground on M, do you have a mathematical mean to handle this problem. For example, assuming M is a rod of cylindrical shape, extending from x = 1 to 2.
FAQ: Floating potential of a conductor in an electrical field
1. What is floating potential?
Floating potential is the voltage that exists on a conductor in an electrical field when it is not connected to any other conductors or a power source. It is the potential difference between the conductor and the surrounding space.
2. How is floating potential different from other types of potential?
Floating potential is unique because it is not influenced by any external factors such as a power source or other conductors. It is solely determined by the properties of the conductor and the electric field it is in.
3. Why is floating potential important to understand?
Floating potential is important in various scientific and engineering applications, such as in plasma physics, spacecraft design, and electronic circuitry. Understanding floating potential allows for better control and manipulation of electric fields and can help prevent unwanted electrical interference.
4. How is floating potential measured?
Floating potential can be measured using a voltmeter or oscilloscope. The conductor is connected to the measuring device, and the voltage difference between the conductor and the surrounding space is recorded.
5. Can the floating potential of a conductor change?
Yes, the floating potential of a conductor can change if the properties of the conductor or the surrounding electric field change. It can also be influenced by nearby conductors or other external factors. However, if the conditions remain constant, the floating potential will also remain constant.
