MHB Flore-D's question at Yahoo Answers involving related rates
  • Thread starter Thread starter MarkFL
    Related rates
The problem involves a spherical raindrop evaporating at a rate proportional to its surface area. The volume of the raindrop is expressed as V = (4/3)πr³, leading to the differential equation dV/dt = -k(4πr²). By equating the two expressions for dV/dt, it is determined that the radius decreases at a constant rate, resulting in the equation dr/dt = -k. Solving the initial value problem with the given conditions leads to the expression for the radius over time: r(t) = -2t + 3. This formula indicates that the radius decreases linearly from 3 mm to 2 mm over half an hour.
MarkFL
MHB
Here is the question:
Please help with differential equations problem solving.?
Assume that a spherical raindrop evaporates at a rate proportional to its surface area. If its radius originally is 3mm, and one-half hour later been reduced to 2mm, find an expression for the radius of the raindrop at any time.
Here is a link to the question:
Please help with differential equations problem solving.? - Yahoo! Answers
I have posted a link there to this topic so the OP may find my response.
Mathematics news on Phys.org
Hello Flore-D,
Let $V$ be the volume of the raindrop in $\text{mm}^3$ at time $t$ in $\text{hr}$. Let $r$ be the radius of the drop at time $t$.
We are told:
$\displaystyle \frac{dV}{dt}=-k\left(4\pi r^2 \right)$ where $0<k\in\mathbb{R}$
Since the drop is spherical, we may state:
$\displaystyle V=\frac{4}{3}\pi r^3$
Differentiate with respect to time $t$:
$\displaystyle \frac{dV}{dt}=4\pi r^2\frac{dr}{dt}$
Equate the two expressions for $\displaystyle \frac{dV}{dt}$:
$\displaystyle 4\pi r^2\frac{dr}{dt}=-k\left(4\pi r^2 \right)$
$\displaystyle \frac{dr}{dt}=-k$
We find that the radius will decrease at a constant rate. This stems from the fact that the derivative of a sphere with respect to its radius is its surface area. Think of a sphere being decomposed into spherical shells. So, we have the initial value problem:
$\displaystyle \frac{dr}{dt}=-k$ where $\displaystyle r(0)=3,\,r\left(\frac{1}{2} \right)=2$
Integrating, we find:
$\displaystyle r(t)=-kt+C$
Use initial value to determine the parameter $C$:
$\displaystyle r(0)=-k(0)+C=3\,\therefore\,C=3$
and so we have:
$\displaystyle r(t)=-kt+3$
Now, use the other known point to determine the constant of proportionality $k$:
$\displaystyle r\left(\frac{1}{2} \right)=-k\left(\frac{1}{2} \right)+3=2\,\therefore\,k=2$
Hence, we find the radius at any time $0\le t$ is given by:
$\displaystyle r(t)=-2t+3$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
