Understanding the Flow Control Principle of Valves
In summary, a valve for flow control, such as a globe valve, works by restricting the cross-section of the flow and increasing friction and turbulence in the process. This results in a decrease in energy and velocity, causing a net static and dynamic pressure change. The exact amount of energy lost due to friction and turbulence is difficult to model, so valve performance is typically determined empirically by the manufacturer.
fonz
151
How exactly would you describe the principle of a valve for flow control?
In a globe valve for example the fluid flows through valve seat and generally leaves the valve with the outlet diameter being the same as the inlet diameter.
My original assumptions were that Bernoulli's principle had to be somehow related but if you ignore friction losses etc. then surely the energy is conserved and the dynamic pressure at the outlet would equal the inlet dynamic pressure due to the diameters being the same. In this case there would be no change in velocity or static pressure.
Energy must be lost somehow for the volumetric flow to change but how?
Some more thoughts...
An decrease in flow area would cause a static pressure drop which would, again assuming no friction losses, have the effect of increasing flow velocity. This I can understand would happen through the inlet and seat of the valve however fundamentally as the fluid leaves the valve the opposite should occur and the velocity should return to its original value.
By this logic there should be no net static or dynamic pressure change across the valve.
In reality the valve restricts the cross-section of the flow, thus increasing the power of friction resisting the flow and also supporting the development of turbulent flow. As a result of these processes, for a given pressure drop the mean velocity of water gets lower.
Likes 1 person
In response to Jano L.
So what you are saying is that energy is lost through friction as heat? I guess this would make modelling the flow through a valve fairly difficult.
I also refer to the image below, theoretically assuming no losses in the pipe to friction and incompressibility etc. if we could somehow control the area of A2 this would have no effect on the net volumetric flow through this section? Therefore the concept of a valve solely relies on the increase in friction?
Friction and also turbulence. The valve may increase the whirling motion of the water which also leads to decrease of pressure, and the friction then leads to loss of even this whirling motion into heat. The picture you posted is very simplified picture of what happens to water. In practice the flow is usually not so simple.
Likes 1 person
fonz said:
... I guess this would make modelling the flow through a valve fairly difficult.
yes. In practice it is done empirically. The result is a curve provided by the valve vendor, Cv vs. position, that allows you to include a head loss term on the RHS of your Bernoulli equation.
Likes 1 person
Related to Understanding the Flow Control Principle of Valves
1. What is the basic principle behind flow control valves?
The basic principle behind flow control valves is to regulate the flow of a fluid by adjusting the size of an opening or passageway. This is typically achieved by using a movable element, such as a valve or a cam, to control the amount of fluid allowed to pass through the valve.
2. What is the purpose of a flow control valve?
The main purpose of a flow control valve is to control the flow rate of a fluid in a system. This allows for precise regulation of flow, which can be important for maintaining the desired pressure, temperature, or volume of the fluid.
3. How do flow control valves work?
Flow control valves work by using a movable element, such as a valve or a cam, to adjust the size of an opening or passageway. This movement is typically controlled by an actuator, such as a motor or solenoid, which responds to signals from a control system.
4. What are the different types of flow control valves?
There are several different types of flow control valves, including globe valves, butterfly valves, ball valves, and needle valves. These valves differ in their design and function, but all work on the same basic principle of regulating flow by adjusting the size of an opening or passageway.
5. How do flow control valves differ from other types of valves?
While all valves have the general function of controlling the flow of a fluid, flow control valves are specifically designed to regulate the flow rate. This is achieved by using an actuator to adjust the size of an opening or passageway, rather than simply opening or closing the valve.
