Flow line in conservative vector field
In summary: Since the force field is conservative, the work done by the force is path independent. This means that the work done by the force from a starting point ##A## to an ending point ##B## is the same for any path you take from ##A## to ##B##. So if the particle starts at point ##A## with potential energy ##f(A)## and moves to the point with potential energy ##f(B)##, then the work done by the force is ##- \displaystyle \int_{\vec c(t)} \vec F \cdot d \vec s = f(B) - f(A)##. This quantity is the same for all paths from ##A## to ##B##. So it must be
Thomas G
Recall that a flow line, c(t), of a vector field F has c'(t)=F(c(t)) at all times t. Show all work below.
a.) Let c(t) be the flow line of a particle moving in a conservative force field F=-grad(f), where f:R^3->R, f(x,y,z) >=0 for all (x,y,z), represents the potential energy at each point in space. Prove that the particle will always move towards a point with lower potential energy. What is the limit of F(c(t)) as t goes to infinity?
F=-grad(f)
c'(t)=F(c(t))
We are trying to show that f(c(t)) is a decreasing function of t. So far, I have that
grad[f(c(t))]=grad(f(c(t))*c'(t) thru chain rule
grad[f(c(t))]=grad(f(c(t))*F(c(t)) because c(t) is a flow line
grad[f(c(t))]=grad(f(c(t))*-grad(f(c(t)) by the definition of F
grad[f(c(t))]=-(grad(f(c(t))^2
But I am not sure if this really helps at all. Is this the right direction to go in, or am I completely off base?
Recall that vectors in a vector field are tangent to the flow lines. Since ##\vec c(t)## is a flow line, you know that ##\vec F(\vec c(t)) = \vec c'(t)##. That is, the vector field of the flow line is equal to the tangent to the flow line for all times ##t##.
You know ##\vec F## is conservative, and so ##\vec F = - \vec{\nabla f} = -(f_x \hat i + f_y \hat j + f_z \hat k)## for some potential function ##f(x, y, z) \geq 0##. The gradient of a function gives the direction of fastest increase. So minus the gradient gives the direction of fastest decrease.
Hence ##\vec F(\vec c(t)) = - \vec{\nabla f}(\vec c(t)) = \vec c'(t)##. Notice the tangent to the flow line is equal to the negative of the gradient of the potential function (which is decreasing). So it must be the case ##\vec c'(t)## is also decreasing. So as the particle moves along the flow line ##\vec c(t)##, its potential energy is decreasing.
Now what about ##\displaystyle \lim_{t \rightarrow \infty} \vec F(\vec c(t))##?
FAQ: Flow line in conservative vector field
1. What is a flow line in a conservative vector field?
A flow line in a conservative vector field is a path followed by a particle or fluid element under the influence of the vector field. It represents the direction of the vector field at any given point and can be visualized as a streamline or pathline.
2. How are flow lines related to conservative vector fields?
Flow lines are closely related to conservative vector fields because they follow the direction of the gradient of a scalar potential function. This means that the work done by the vector field along a closed loop is zero, indicating that the field is conservative.
3. What is the significance of flow lines in conservative vector fields?
Flow lines are important in conservative vector fields because they provide a visual representation of the direction and magnitude of the field. They also help in understanding the behavior of particles or fluids in the field and can be used to calculate the work done by the field.
4. Can flow lines intersect in a conservative vector field?
No, flow lines cannot intersect in a conservative vector field. This is because the direction of the field at any point is unique and there can only be one path that follows the direction of the field. If two flow lines were to intersect, it would indicate a change in direction of the field, which is not possible in a conservative vector field.
5. How can flow lines be used to determine the potential function of a conservative vector field?
Flow lines can be used to determine the potential function of a conservative vector field by calculating the line integral along a flow line. The potential function is given by the negative of this line integral. By calculating the line integral along multiple flow lines, the potential function can be determined for the entire field.
