Flow over a feathered propeller
In summary, the PT6 and PW120 turboprop engines are started feathered to minimize the load on the starter. The flow over the propeller is not separated during this process, and the engines can be started in a fine pitch.
LaxeyT
The propeller of a turboprop engine is started with the propeller blades feathered (in-line with the flow): see video: . As the propeller speeds up and reaches idle speed while still feathered, and the incidence onto the blades is very high, does this mean that the flow over the blades is separated? Is this why they are started feathered, so that there is little load from the propeller?
Thanks.
I have no idea about separation. Sorry.
I can only speculate as to why they're keeping the prop feathered. The load upon the engine is actually higher that way, but it would minimize the linear strain upon the mounting system.
It would be super hard on the starter for the TPE-331s if they were started feathered so they aren't started in the feathered position.
PT-6 have a very different design than the single spool TPE331 which allows them to be started feathered.
If you've ever seen a mitsibushi MU2 starting, you will understand why the PT6 guys start feathered.
They do it because they can and the benefit is a propeller that isn't screaming away it idle but rather gently turning.
Yes, I think the PT6 () and the PW120 as well () have separate power turbines, where I think it is common to start the turboprop feathered. On these engines the starter doesn't turn the propeller directly, but my question is is the propeller unloaded or loaded by starting feathered. I think you are saying it is loaded a little, so it doesn't overspeed while coming to idle. However, I am wondering what is the condition of the flow over the propeller, and whether these engines could be started in a fine pitch as well, for a low load condition?
I'm out of here now; I was never turbine-rated. My only thought was about the prop drag on the gearbox vs. thrust on the staunchion. That was based upon it being a static engine test. (At least, I hope that's what it was, because otherwise it was the ugliest aeroplane that I've ever seen in my life. :biggrin:)
FAQ: Flow over a feathered propeller
What is "flow over a feathered propeller"?
"Flow over a feathered propeller" refers to the movement of air or water over the blades of a propeller that can be rotated or tilted to change the angle of attack, also known as feathering. This technique is commonly used in aircraft and marine vehicles to improve efficiency and control.
How does feathering affect the performance of a propeller?
Feathering can significantly impact the performance of a propeller by changing the angle of attack and the amount of lift and drag it produces. This can result in increased efficiency, reduced noise and vibration, and improved maneuverability.
What factors influence the flow over a feathered propeller?
The flow over a feathered propeller is influenced by several factors, including the speed and direction of the air or water, the angle of attack of the blades, the shape and design of the propeller, and any external forces such as wind or waves.
How is the flow over a feathered propeller studied?
Scientists use various methods to study the flow over a feathered propeller, including computational fluid dynamics (CFD) simulations, wind tunnel experiments, and field tests. These techniques allow researchers to analyze the flow patterns, pressures, and forces acting on the propeller blades.
What are the potential applications of studying flow over a feathered propeller?
The study of flow over a feathered propeller has many potential applications, including improving the efficiency and performance of aircraft and marine vehicles, reducing fuel consumption and emissions, and enhancing safety and control in extreme weather conditions.
12K
