I Flow rate calculation for laser cutting nozzles
  • I
  • Thread starter Thread starter Adam Bryan
    Gas flow
Calculating the required gas flow for laser cutting nozzles involves understanding the relationship between nozzle orifice size and pressure. Users seek to create an Excel calculator that can determine flow rates in SCFM or SCFH based on these parameters. However, accurate data often comes from manufacturers, and discrepancies can arise during the sales process. Real-time testing with flow meters is recommended to obtain precise flow rates, as these depend on the entire air supply system, including nozzle diameter and internal shape. A comprehensive understanding of fluid dynamics is essential for accurate calculations and flow assessments.
Adam Bryan
TL;DR Summary
Trying to calculate required gas flow through a given nozzle....
I am in need to calculate the required gas flow for a given nozzle orifice. In laser cutting we use various "nozzle orifice sizes" to cut different materials. For example, when cutting 1/4" mild steel we would use a 5mm orifice nozzle using 20 bar. I would like to make a calculator in excel that you just plug in the nozzle orifice size and pressure required. The calculator would then tell you the flow rate in SCFM or SCFH and the minimum pressure that is required to maintain this flow and pressure.
Any help would be awesome! thank you!
Lnewqban said:
Welcome, Adam!
Shouldn't that information come from the manufacturer of the nozzle?
Please, see:
https://thermalprocessing.com/optimizing-gas-supply-for-industrial-lasers/
Unfortunately the sales process gets involved and the end users are given numbers that are not real. I happen to work at one of the Mfg's and our calculations all come up incorrect. We recently purchased a flow meter and are going to run real time tests as to what the flow rates really are per nozzle type and orifice diameter. I am searching for someone who has the equations to calculate flow rate through a given nozzle.
Adam
If the air flow path is "large" compared to the nozzle orifice diameter, and there are minimal obstructions to air flow in that supply path, then you should be able to use an online orifice flow calculator. Unfortunately, to fully explain the previous sentence takes a full course in fluid dynamics.
The problem is that orifice flow calculators take as input the air pressure at the orifice, and that pressure is always lower than the pressure from the pressure regulator. How much lower can be calculated for simple flow paths, but you really need that course in fluid dynamics to be able to do it right.
Your flow meter should be able to give you the flow rates that you are looking for. Just be advised that you need to measure the flow using the exact air supply system from a real machine. The flow through a particular nozzle is a function of the nozzle diameter, nozzle internal shape, and the tubing and any valves from the pressure regulator to the nozzle.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
