artis
- 1,481
- 976
For applications where the output has considerable ripple or spikes often just using electrolytic capacitors for DC smoothing is not enough because electrolytics themselves have some inductance and series ESR which is mostly the result of their inner structure (wire leads, pins, foil)
I was thinking , are there in existence such electrolytic capacitors which would have 4 leads, 2 on each side where one on each side connects to one foil and the other on each side to the other foil. The capacitor itself would then essentially be part of the wire as well as a capacitor, the current instead of flowing in and out of the leads and into the foil would just flow through the capacitor foil.
Think of it like a long transmission line situation compressed into a few cm of space whereby you have both wires/traces as well as distributed capacitance.
Wouldn't this minimize ESR and lower inductance?
Also the foil ends could be made similar to how Tesla thought to make their new tabless battery design whereby instead of leads the end of the whole foil is used for current transfer.?
Are there such capacitors or anything similar?
