MHB Flowerchild1993's question at Yahoo Answers regarding minimizing cost of fence
  • Thread starter Thread starter MarkFL
The discussion focuses on finding the optimal dimensions for a rectangular field with an area of 770 square feet to minimize fencing costs, with two sides costing $3 per foot and the other two sides costing $8 per foot. The cost function is derived and simplified to express it in terms of a single variable. By differentiating the cost function and applying the second derivative test, the minimum cost dimensions are calculated. The resulting dimensions are approximately x = 4√1155/3 and y = √1155/2. This mathematical approach provides a clear solution to the problem posed by Flowerchild1993.
MarkFL
MHB
Here is the question:
Calculus help! Word problem?
A rectangular field is to be enclosed on four sides with a fence. Fencing costs $3 per foot for two opposite sides, and $8 per foot for the other two sides. Find the dimensions of the field of area 770 ft squared that would be the cheapest to enclose.
Here is a link to the question:
Calculus help! Word problem? - Yahoo! Answers
I have posted a link there to this topic so the OP can find my response.
Mathematics news on Phys.org
Hello flowerchild1993,
Let's let $x$ be the length of one pair of sides, for which fencing costs $C_x$ in dollars per foot and $0$ be the length of the other pair of sides, for which fencing costs $C_y$ in dollars per foot. All measures and constants are positive.
The cost function is therefore:
$$C(x,y)=2C_xx+2C_yy$$
Let the area of the field be $A$, and so we have:
$$A=xy\,\therefore\,y=\frac{A}{x}$$
and so we may write the cost function in terms of one variable $x$:
$$C(x)=2C_xx+2AC_yx^{-1}$$
Now, to find the extrema, we differentiate with respect to $x$ and equate to zero:
$$C'(x)=2C_x-2AC_yx^{-2}=0$$
Multiplying through by $$\frac{x^2}{2}$$ we may arrange this as:
$$x^2=\frac{AC_y}{C_x}$$
Taking the positive root, we find:
$$x=\sqrt{\frac{AC_y}{C_x}}$$
And so:
$$y=\frac{A}{\sqrt{\frac{AC_y}{C_x}}}=\sqrt{\frac{AC_x}{C_y}}$$
This is why I used variables to denote the constants of the problem...we can now see how the dimensions of the field will change with respect to changes made to any of the constants. We see that if $C_x$ increases then $x$ will decrease and $y$ will increase, etc. We also see that:
$$\frac{x}{y}=\frac{C_y}{C_x}$$
This ratio also tells us how the dimensions will vary based on the costs.
Using the second derivative test for relative extrema, we find that:
$$C''(x)=4AC_yx^{-3}>0$$ for $$x>0$$ which we have assumed, and so we know this critical value is at a minimum.
Now it's just a matter of using the given data to find the required dimensions. Let's let $x$ be the pair of sides with the cheaper fencing, so we have:
$$C_x=3,\,C_y=8,\,A=770$$
$$x=\sqrt{\frac{770\cdot8}{3}}=\frac{4\sqrt{1155}}{3}$$
$$y=\sqrt{\frac{770\cdot3}{8}}=\frac{\sqrt{1155}}{2}$$
To flowerchild1993 and any other guests viewing this topic, I invite and encourage you to post other optimization problems here in our http://www.mathhelpboards.com/f10/ forum.
Best Regards,
Mark.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
