Fluid as a medium to transfer electricity
In summary, the Hydro-Clock utilizes a fluid as an electrolyte to transfer electricity from an internal battery, similar to a regular galvanic cell. It works by extracting electrons from water molecules and converting them into a steady stream of electrical current. The clock can be placed next to a bubbling sea chest in an aquarium for a unique display. However, the explanation provided on the product's page on ThinkGeek is incorrect.
GDBot
http://www.physlink.com/estore/cart/Hydro-Clock.cfm
I think it just uses the fluid as a medium to transfer electricity from an internal battery, my friends aren't so sure. Any thoughts on this out there?
I am thinking it is something like a ‘lemon’ clock, except instead of a lemon one just provides some other electrolyte. There could be the makings of a battery exposed to the electrolyte tank which, when liquid is added, generates the current to run the clock.
You are right. More accurately, the fluid serves as an electrolyte which transfers charge between two electrodes that make up the battery for the clock. The principle is the same as that of any regular galvanic cell.
They have these on thinkgeek as well.
http://www.thinkgeek.com/homeoffice/lights/757e/
Only their explanation is wrong!
thinkgeek said:
The internal converter simply extracts electrons from water (or other liquid) molecules and provides a steady stream of electrical current acting as a fuel cell to generate power to the clock.
Electrons are "extracted" from the anode, not from water.
Put it right next to the bubbling sea chest in the aquarium.
FAQ: Fluid as a medium to transfer electricity
What is fluid as a medium to transfer electricity?
Fluid, in this context, refers to a liquid or gas that is used to conduct electricity. It is often used as an alternative to traditional solid conductors like metal wires.
How does fluid conduct electricity?
Fluid conducts electricity through the movement of charged particles called ions. In the case of liquids, the ions are typically dissolved in the fluid, while in gases, they are present as separate atoms or molecules.
What are the advantages of using fluid as a medium for electricity?
There are several advantages to using fluid as a medium for electricity. It is more flexible and can be used in situations where solid conductors would be difficult or impossible to install. Fluids are also less prone to damage from environmental factors like corrosion, and they can handle higher voltages without breaking down.
What are some common applications of fluid as a medium for electricity?
Fluid is commonly used in batteries, where it acts as an electrolyte to facilitate the flow of electricity between electrodes. It is also used in some types of fuel cells, as well as in high-voltage power lines and transformers.
Are there any limitations or drawbacks to using fluid as a medium for electricity?
One limitation of using fluid as a medium for electricity is that it typically has a lower conductivity than solid conductors, so it may not be suitable for all applications. Additionally, some fluids may be flammable or toxic, making them potentially hazardous to handle. Finally, the cost of using fluid as a medium may be higher than using traditional conductors in some cases.
