Fluid dynamics (2nd year undergrad) question on jet incident on a plate
This balances out the force from the change in momentum of the jet. In summary, the pressure on both sides of the plate is equal due to Bernoulli's law, resulting in a net force of zero.
hai2410
A circular jet of water of radius r1 is propelled vertically downwards and hits
a circular plate of radius r2 (> r1 ) so that the centre of the jet is incident onto the
centre of the plate. The velocity of the jet as it hits the plate is v and is normal to
the plate.
Show that for a plate of radius r=\sqrt(2)r1 the net force on the plate due to the
change in momentum of the fluid and the differences in pressure on each side of
the plate is zero.
[You may assume that the velocity of the water changes direction from being
normal to the plate to lying in the plane of the plate as it hits the front of the plate
and that the rear of the plate is covered by a layer of the water that has been
brought to rest.]
Bernoulli:
0.5p v^2 + P =constant (p being density, P being pressure, v being velocity)
I can find out the thickness of the film as a function of radial distance from centre under the assumption that the pressure is equal on the surface of the jet as it was in the incident jet [and thus using Bernoulli and conservation of mass], and I can work out the force on the plate due to the change in momentum of the jet normal to the plate.
I can also work out for a particular stagnation point above the centre of the plate, that the pressure [by Bernoulli] is P0 + 0.5pv0^2 where I've called the jet initial pressure P0, and initial velocity v0.
However both of these forces would act down on the plate, so that it was blasted away from the incident jet (as you'd expect in real life). I therefore can't think of any force which would act toward the jet, and so have no idea how to solve this problem.
Thanks for any help you can give! :)
PS for this part you don't take into account the weight of the fluid, that comes later apparently
You don't need to figure out the thickness of the film. You do need the force exerted on the plate, however, but that doesn't require you to know the thickness of the film.
It's actually P0-0.5pv0^2. Bernoulli's law says that 0.5p v^2 + P =P0, where P0 is the pressure at a place where velocity is 0, so P=P0-0.5pv^2.
The pressure acts upwards because on the other side of the plate, the pressure is higher.
FAQ: Fluid dynamics (2nd year undergrad) question on jet incident on a plate
1. What is fluid dynamics?
Fluid dynamics is a branch of physics that studies the behavior of fluids (liquids and gases) in motion. It involves the study of how fluids move, flow, and interact with their surroundings.
2. What is a jet incident on a plate in fluid dynamics?
A jet incident on a plate refers to the scenario where a stream of fluid (jet) impacts a stationary flat surface (plate). This is a common phenomenon in many engineering applications, such as in aerodynamics and hydraulics.
3. What factors affect the behavior of a jet incident on a plate?
Several factors can influence the behavior of a jet incident on a plate, including the velocity and density of the jet, the angle of incidence, the properties of the fluid and the plate, and the distance between the jet and the plate.
4. How is the flow pattern of a jet incident on a plate studied?
The flow pattern of a jet incident on a plate can be studied using experimental methods, such as flow visualization techniques and measurements of pressure and velocity. It can also be analyzed using theoretical models and computational fluid dynamics simulations.
5. What are some applications of studying jet incident on a plate in fluid dynamics?
The study of jet incident on a plate has many practical applications, including in the design of aircraft wings, wind turbines, and fluid machinery. It is also relevant in understanding environmental processes, such as the impact of ocean currents on coastal structures.
