WhiteWolf98
- 86
- 5
- Homework Statement
- Air flows steadily in a long pipe. The static, absolute pressure and the temperature at the pipe inlet are ##77~kPa## and ##264~K## respectively. At the outlet the static, absolute pressure and the temperature are ##44~kPa## and ##244~K## respectively. Assuming that the average air velocity at the inlet is ##V=202~ms^{-1}##, use the mass conservation principle and the state equation for an ideal gas to determine the average air velocity (in ##ms^{-1}##) at the outlet.
- Relevant Equations
- ##{\dot m}_{in}= {\dot m}_{out}##, ##PV=nRT?##
I understand that ##\dot m=\rho Q## and ##{\dot m}_{in}= {\dot m}_{out}## . So one can say that ##\rho Q_1 = \rho Q_2##. But I'm not sure if that equation is correct. I don't know if the density remains constant, or the volume flow rate. And then how I'm also supposed to tie a state equation in it too... I've thought about the problem a lot, but I don't seem to be getting anywhere. Any help in the right direction would be appreciated; thanks!
