stuplato
- 34
I just like someone to help check my answers please
Gil is a perfectly spherical fish bred specifically for use in physics problems. Gil has mass of 33.5 kg. By inflating/deflating his air bladder, Gil has the ability to change his volume while his mass does not change appreciably. Gil sleeps in a small cylinder chamber. The small chamber is connected to a larger chamber by a tapering passageway. The walls of the containers are made of aluminium with a small glass window (diameter = 0.4 m) in the larger chamber. Both chambers are sealed by large (thin) weights that can move up/down as water levels change. Gil is initially 5 m from the bottom of the smaller cylinder.
Part A: Both tanks are filled with water (p=1000 kg/m^3). The small weight has a mass of 10,000 kg and radius of 2 m. The large weight has mass of 2,000,000 kg and radius of 10m. If the water is 15 m from the floor, what is the water level in the larger cylinder? The system is in equilibrium. I get 9.03 m
Part B: Gil adjusts his position in the tank by adjusting his bladder (and thus his volume). What must Gil's radius be to remain stationary in the water tank? I get 0.2 m
Part C: Gil wants to rise to the top of the tank. If he doubles his radius, what will his resultant acceleration be? Ignore frictional effects. I get 68.6 m/s^2
Part D: How long will it take Gil to strike the floating weight at the top of the tank? Ignore friction and turbulence. What will his speed be? I get .274 s and 18.8 m/s
Part E: In order to conduct an experiment, a scientist wishes to force gil into the larger tank. She accomplishes this by adding an additional 63,000 kg of mass to the smaller cylinder. Qualitatively describe the acceleration and velocity. I put: The velocity of the small disk will change until it and the acceleration will equal zero. The acceleration changes due to changes in Net Force by changes in pressure
Part F: Calculate the initial accelerations of both the small and large weights at the moment the 63,000 kg mass is added. Are these values the same? Why or why not? I get 8.49 m/s^2 for small and .309 m/s^2 for large. No they are not same because they are spread over different areas
Part G: What will the new water levels be once the system reaches equilibrium? i get 12.91 for small and 9.45 for large
Part H: Gil is carried into large tank by flow of water. If he enters the large end of the passage (radius 2 m) with velocity of 3.2 m/s, with what velocity will he come out of the other end (radius .5 m)? I get 12.8 m/s
There is more, but I like to know this part is right first before continuing...![Smile :smile: :smile:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![Egg on Face o:) o:)](/styles/physicsforums/xenforo/smilies/eggonface.png)
