Fluid flow over part of an aircraft wing
In summary, the PhD left you a mystery about how turbulence and swirl can be caused by airflow over only a fraction of the wing surface. This mystery is relevant to what the user asked, which has nothing to do with the angle of attack. The user is interested in knowing whether such partial flow will cause turbulence and swirl or not. According to the PhD, this situation would be worse because on aircraft, even though there is airflow over the whole wing, the effect can be more pronounced.
P G I
Recently, on a conversation with PhD in Engineering, I came to know that if, instead of the whole wing, air/fluid flows over part of it, then that will cause great turbulence and swirl. When I asked him for reference, he said that it can be found in any book on Aerodynamics. But still today, I haven't been able to find out.
To be more precise, let's start with two imaginary scenario. First, there is an aircraft wind tested in an wind tunnel where everything goes according the Bernoulli's principle and other known factors. Now, instead of wind tunnel, we used a small sized fan that has much less diameter than the length of the wing, does that will cause big turbulence and swirl over the part of the wing that hasn't got any kind of airflow?
Yes. It's hard to make a jet of air that doesn't interact with stationary air either side of it. Certainly it would be hard to do with just a fan. The jet would tend to diverge creating air flow over unintended parts.
You might be able to solve the problem by adding fences/strakes to contain the airflow over the of of interest.
So the PhD left you a mystery...
https://en.wikipedia.org/wiki/Stall_(fluid_mechanics)
256bits said:
Can't understand how that is relevant to what I have asked. What I want to know has nothing to do with the angle of attack but rather flow of air/fluid over a fraction of the wing surface instead of the whole wing.
I know that jets always tend to diverge and it's a common experience we can gather from fans used for everyday cooling. But actually I don't have any problem if the jet tends to divert. What I want to know is whether such partial flow will cause turbulence and swirl or not. My common sense tells me that there isn't any reason for creation of turbulence and swirl for such reason. And, by the way, the jet will flow on both side of the wing just not over the whole part of it.
All I can say is, you sure.
Seems to be a lot of swirl and turbulence as the flow separates from the wing, from front to rear. ( and not side to side )
Interpretation of what the PhD was saying, between you and me, I guess is different.
PGI.. look up how wing tip vortices are formed. If the pressure is increased below a wing the air tries to escape in all directions, including sideways. It doesn't just flow rearwards.
Does that mean formation of turbulence and swirl to a very high degree?
If you only have airflow over part of the length of a wing you will only get lift over that part.
Lift comes from lower pressure above the wing with some higher pressure below the wing. That means still air above the wing will flow along the wing into the moving air lift region, while flowing air below the wing will spread out along the wing into the still region.
In the transition region there will be air departing the trailing edge from above and below with very different velocities = turbulence.
Why would you want to test only part of a wing?
What does high degree mean? It's significant enough to make high aspect ratio wings more efficient than low aspect ratio wings. It's an issue that has affected the design and performance of everything from WW2 fighter aircraft to F1 racing cars. Ditto modern airliners where, I believe winglets significantly reduce drag and improve fuel consumption.
And the situation you describe would be worse. On aircraft you get this effect even though there is airflow over the whole wing. It could be more pronounced with airflow only over part of the wing
@P G I, please clarify your question. Does it pertain to real aircraft or only to the validity of a wind tunnel test?
Consider a fan alone in an empty room. All of the air blown out the front must re-circulate to the back of the fan to maintain continuity.
Likes CWatters
I am very confused by all of this. The specific example given, which is a fan blowing over a portion of a wing but not all of it, is kind of nonsensical when the metric by which you evaluating the results is minimizing "swirl", which I will henceforth call vorticity. A fan, by default, adds considerable vorticity to the flow downstream of it; after all, it is using rotating blades to impart motion to the flow.
If you instead just use a hypothetical blower upstream of your wing that creates a laminar jet blowing over a portion of the wing, then you still have vorticity that is generated, this time around the edges of the jet. You have a jet at one speed and a free stream at a different speed, which sets up a shear layer. That shear region generates vorticity and is subject to the Kelvin-Helmholtz instability. In fact, this happens regardless of whether there is a wing in the jet or not.
Likes berkeman and CWatters
Sorry for the inconvenience, but at present I can't clearly define (actually not even able to give some hint about that. So, as per you, the the vortex will appear as the higher pressure stagnant air from below will come up and mix with lower pressure air above. But, if somehow that's prevented, then the possibility of formation of turbulence can be minimized.
Thanks for correcting me, you have correctly said that to get a laminar flow over a part of a wing, a blower is needed. And I must admit that I have forgot to mention the laminar flow. Whatsoever, I think you too want to say that the vorticity/turbulence will be caused when the higher pressure air from below will come up and mix with lower pressure air above the wing, right?
No, what I am saying is that any time you have a stream of air moving through other air that has a different speed, there will be vorticity generated regardless of whether a wing is present or not.
Does such phenomenon occurs in our everyday fans that we use for cooling?
Again, every time a fluid with one speed moves by the same or a different moving at a different speed, it generates shear and vorticity. This does include just a fan on a desk.
Do this effects slow down the fluid flow?
Is there any formula from which we can detect the loss in velocity?
Fluid mechanics does not have a lot of examples of being able to use simple formulae to represent what is otherwise and extremely complex physical phenomenon. Your best bet is to look up the various sources on the behavior of jets. There are various models for how jets behave. In the simplest example, you can simply look at how it diverges and use the area of the jet at a given location along with conservation of mass to determine the average velocity across it at that location. More detail than that requires more careful consideration of viscosity.
Likes anorlunda
Experiment has been performed countless times since the early days of winged flight.
The propeller is smaller the wing length.
One has the slipstream of the propeller and wing interaction, and if that is what the PhD is talking about, is it actually mentioned in any book on aerodynamics??. Rather the stall characteristics of wing are mentioned more likely for pilot flight school and beginning aerodynamic courses,
If you are interested here is a mild discussion of slipstream/ wing interaction.
https://www.researchgate.net/publication/27341924_Propeller_Wing_Aerodynamic_Interference
You can download as PDF.
Note that the slipstream swirl has an effect on the rudder of the plane, pushing it more to one side than the other.
That would be most important on takeoff at full, or near full throttle, where the pilot had to compensate.
FAQ: Fluid flow over part of an aircraft wing
1. What factors affect the fluid flow over part of an aircraft wing?
The fluid flow over an aircraft wing is affected by several factors, including the shape and curvature of the wing, the angle of attack, the speed and density of the air, and the presence of any obstructions or aerodynamic devices on the wing.
2. How does the angle of attack impact the fluid flow over an aircraft wing?
The angle of attack, which is the angle between the wing and the direction of the oncoming air, plays a crucial role in determining the lift and drag forces on the wing. A higher angle of attack can increase lift but also create more drag, while a lower angle of attack may decrease lift but also reduce drag.
3. What is the boundary layer and how does it affect fluid flow over an aircraft wing?
The boundary layer is the layer of air closest to the surface of the wing. This layer experiences a decrease in velocity due to friction with the wing's surface, creating a thin layer of slower moving air. This layer can affect the overall flow of air over the wing and impact the lift and drag forces.
4. How do aerodynamic devices, such as flaps and slats, impact the fluid flow over an aircraft wing?
Aerodynamic devices, such as flaps and slats, can be extended or retracted to change the shape and curvature of the wing. This can alter the flow of air and allow for adjustments in lift and drag forces, making it easier for the aircraft to take off, land, or maneuver.
5. What techniques are used to study and analyze fluid flow over an aircraft wing?
Scientists use a variety of techniques to study and analyze fluid flow over an aircraft wing, such as wind tunnel testing, computational fluid dynamics (CFD) simulations, and flight testing. These methods allow for a better understanding of the complex flow patterns and forces involved in aerodynamics, leading to improvements in aircraft design and performance.
