j3dwards
- 32
Water is flowing along a pipe. Points B and C in the pipe are at the same height but point A is at a higher elevation.The pipe has the same cross-sectional area at points A and B but is wider at point C. Rank in order from largest to smallest, the pressures at the three points A, B, C. Briefly explain your reasoning.
Bernoulli''s equation?
Largest to smallest in order: A, B, C
Pressure highest at A because A is uphill, then B because it has a smaller cross sectional area than C, and then C because greatest cross sectional area.
But I'm not sure if pressure is higher at C because it's pushing fluid uphill?
