I Fluid flow through a pin-hole of x diameter in a closed container
Fluid flow through a closed cylindrical vessel with a pinhole is influenced by both air entering the vessel and the properties of the liquid, including surface tension and wall flexibility. The flow is likely to be unsteady, characterized by intermittent air intake and liquid discharge. The presence of a D-sized hole complicates the dynamics, as it requires consideration of surface tension rather than solely relying on Bernoulli's equation. The compressibility of the air above the liquid further affects the flow behavior. Overall, this scenario presents unique challenges that have not been extensively studied in conventional fluid dynamics problems.
AspiringMonkey
TL;DR Summary
A container is filled with a specific fluid and has a hole on the side. How big can the hole be before the fluid starts flowing out while air flows in? Air must flow in since the container is closed. Capillary forces must be taken into account. The wall has a specific thickness.
Greetings,
I've come across lots of exercises regarding Bernoulli's equation. However, never seen one where the top of the vessel is closed, and fluid flow exists via gas (air) going in. Has this problem been studied in the past?
Assume a cylindrical vessel filled to the maximum with a D-sized hole on the side. The wall thickness and the surface tension/capillary forces are significant. Air must go inside the vessel for the liquid fluid to come out.
Welcome to PF.
It is unlikely that the flow will be steady because the walls are flexible, and the air contained above the liquid is compressible. Systems with only one port tend to gulp air, then run liquid for a while, before taking another gulp of air and repeating.
What is a D sized hole ?
I think you are going to have to consider surface tension. Not Bernoulli's.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
