Fluid Least Likely to Leak Through O-Ring?
  • Thread starter Thread starter BasketDaN
    Fluid
For a prototype requiring minimal leakage between a steel rod and an O-Ring, selecting a fluid that is chemically compatible with the O-Ring material is essential. The fluid must remain liquid at 25 degrees Fahrenheit and should ideally be relatively incompressible. Options discussed include hydraulic fluid, engine oil, canola oil, glycerin, and antifreeze, all of which should avoid significant water content. The viscosity of the fluid is a key factor in preventing leaks, and the surface finish of the steel rod also plays a role in the effectiveness of the seal. Ensuring proper gland design alongside the right fluid choice will help achieve a leak-free installation.
BasketDaN
96
I am building a prototype, and I was just wondering what fluid I should use that is the least likely to seap through the interface of a steel rod and a small O-Ring, as the steel rod moves forward through the O-Ring. This fluid should not freeze at 25 degrees fahrenheit, and should be relatively incompressible.
Thanks!
You need to select something that is chemically compatible with the elastomer the o-ring is made of. That combined with proper gland design will be the only way to ensure a leak free installation.
This actually doesn't need to last long, just a day or two so I can use this once. High performance also isn't particularly important, just that nothing leaks out the seal. I guess I am wondering what the highest viscosity fluid would be that wouldn't freeze in a freezer. (Is it viscosity that would determine this?)
Hydraulic fluid, engine oil, canola oil, glycerin, antifreeze, etc...pretty much anything that's doesn't have water as a major component.
What's the surface finish of the steel rod?
Thread 'What type of toilet do I have?'
I was enrolled in an online plumbing course at Stratford University. My plumbing textbook lists four types of residential toilets: 1# upflush toilets 2# pressure assisted toilets 3# gravity-fed, rim jet toilets and 4# gravity-fed, siphon-jet toilets. I know my toilet is not an upflush toilet because my toilet is not below the sewage line, and my toilet does not have a grinder and a pump next to it to propel waste upwards. I am about 99% sure that my toilet is not a pressure assisted...
After over 25 years of engineering, designing and analyzing bolted joints, I just learned this little fact. According to ASME B1.2, Gages and Gaging for Unified Inch Screw Threads: "The no-go gage should not pass over more than three complete turns when inserted into the internal thread of the product. " 3 turns seems like way to much. I have some really critical nuts that are of standard geometry (5/8"-11 UNC 3B) and have about 4.5 threads when you account for the chamfers on either...
