CHeema
- 3
Dear All!
I am in need of the follwing few questions regarding Gas Turbines and Compressors. It will be very nice and helpful if you people reply...an earliest reply will be appriciated
why the flow channel in turbomachines usually does not have parallel hub and casing walls
how the static pressure changes qualitatively between in- and outlet in an axial action and reaction turbine.
Sketch a qualitative pressure distribution over an airfoil.
why compressor blades feature little curvature and are comparatively thin whereas turbine blades are highly curved and tend to be thicker.
why it is more difficult to diffuse (i.e. decelerate) than to accelerate flow.
how the cross section area changes for a parallel wall annular flow channel upon change in flow angle.
Explain why the flow channel in turbomachines usually does not have parallel hub and casing walls and how you as designer would determine its shape.
I know these are a lot of questions but i am in real need of these...
Regards
Cheema
Regards
Cheema
