Fluid Machinery Turbine Radial Flow
In summary: By neglecting the thickness of the runner vanes, we can determine the net turbine head, the turbine discharge, and the turbine brake power. In summary, to determine these values for a radial-flow reaction water turbine operating under BEP conditions, we need to know the speed, diameter, inlet angle and width of the runner vanes, and inlet guide-vane angle, as well as the hydraulic and overall efficiencies of the turbine.
Dibbs
The speed of a radial-flow reaction water turbine operating under BEP conditions is 1200 rpm. The diameter of the turbine runner is 0.25 m, the inlet angle and width of the runner vanes are 125° and 70mm respectively, and the inlet guide-vane anle is 25°. The hydraulic and overall efficiencies of the turbine are 86.5% and 81% respectively. Neglecting the thickness of the runner vanes determine the net turbine head, the turbine discharge, the turbine brake power
Tω/γQH = η (overall)
Hm/H = η (mech)
Q=AV
u=rω
Given N=1200 rpm we can find tangential velocity of runner u = rω=15.71 m/s
Since we know the inlet guide angle 25°, the angle of runner vane 125°, and u and we can draw triangle to represent the fluid relative, absolute and radial velocities and thus calculate the radial velocity. Using Q =AV we can determine Q the turbine discharge. For BEP we can can determine H as we know runner diameter D and speed n and can obtain phi at BEP from charts. For turbine brake power =γQHm and Hm can be found since we know H
Not sure of this approach as the question did not refer to the efficeincy vs specific speed chart where I estimated phi from. Also solving the triangle in that way seems a bit dodgy.
Would love to hear of any other approach to this
Thank you
statement, all variables and given/known data[/b]
Given N=1200 rpm we can find tangential velocity of runner u = rω= 15.71 m/sSince we know the inlet guide angle 25°, the angle of runner vane 125°, and u and we can draw triangle to represent the fluid relative, absolute and radial velocities and thus calculate the radial velocity. Using Q =AV we can determine Q the turbine discharge. For BEP we can can determine H as we know runner diameter D and speed n and can obtain phi at BEP from charts. For turbine brake power =γQHm and Hm can be found since we know HTo determine the net turbine head, we can use the equation:H = (η mech) x Hmwhere η mech is the hydraulic efficiency, and Hm is the mechanical head. The turbine discharge, Q, can be found using the equationQ = AVwhere A is the area of the turbine runner, and V is the velocity of the water flow through the turbine. The turbine brake power can be calculated using the equationTBP = γQHmwhere γ is the specific weight of the water, Q is the turbine discharge, and Hm is the mechanical head.
Related to Fluid Machinery Turbine Radial Flow
1. What is a fluid machinery turbine radial flow?
A fluid machinery turbine radial flow is a type of turbine that converts the energy of a flowing fluid, such as water or steam, into mechanical energy. It typically consists of a set of rotating blades that are driven by the fluid and connected to a shaft, which can then be used to power other machinery or generate electricity.
2. How does a fluid machinery turbine radial flow work?
A fluid machinery turbine radial flow works by taking advantage of the principle of fluid dynamics, where the kinetic energy of a fluid in motion can be converted into mechanical energy. The fluid enters the turbine through an inlet and flows through the blades, causing them to rotate and transfer their energy to the shaft. The fluid then exits through an outlet and continues on its path.
3. What are the main applications of fluid machinery turbine radial flow?
Fluid machinery turbine radial flow is commonly used in various industries and processes, such as hydroelectric power generation, steam turbines in power plants, and water pumps for irrigation and water supply. It can also be found in aircraft engines and other mechanical systems where fluid energy needs to be harnessed.
4. What are the advantages of using fluid machinery turbine radial flow?
One of the main advantages of fluid machinery turbine radial flow is its high efficiency in converting fluid energy into mechanical energy. It also has a simple design and can be easily scaled for different applications. Additionally, it has a lower maintenance cost compared to other types of turbines.
5. What factors affect the performance of fluid machinery turbine radial flow?
The performance of a fluid machinery turbine radial flow can be affected by several factors, such as the type and properties of the fluid being used, the design and size of the turbine, and the operating conditions. Other factors that may influence its performance include the maintenance and upkeep of the turbine, as well as any external factors such as temperature and pressure changes in the fluid.
