Fluid mech. and heat transfer prereq.
In summary: That should be enough for most heat transfer courses, and they'll usually cover more advanced topics in fluid dynamics than statics and dynamics.
helpmeoutpls
There is a course at my school called nuclear power engineering. It's an optional course, but it sounds important for a nuc engineer. The course has two prerequisite courses: fluid mech, and heat transfer which i can take as electives. The thing is that I didn't take statics or dynamics (not required or even recommended), and i can't fit them into my schedule.
My counselor told me that I can take fluid mech and heat transfer without statics and dynamics.
Would it be a reasonable step to take fluid mech, and heat transfer without a solid knowledge in statics and dynamics? Are they heavily based on them, or could someone get away with only knowing the basics of mechanics?
Thanks
Hm... fluid mechanics IS "statics and dynamics", except that fluids (especially gases) throw a few curve balls compared with solids.
So it depends very much on the level of the course and the level of your knowledge IMO.
You should be OK for a first course in heat transfer - but a more advanced heat transfer course might require fluid mechanics as a prerequisite.
In the most basic sense, statics and dynamics are among the same family of science, namely mechanics. For most undergraduate courses, there won't be much overlap, however. Most first courses in fluid dynamics will use essentially no advanced topics from those other two subjects. The more important bit of overlap will most likely just be understanding how to sum forces.
Fluid dynamics comes into play in heat transfer when you deal with convection (or convective heat transfer). So, I'd take fluid dynamics first, especially if they cover concepts dealing with momentum/heat transfer analogies in the heat transfer course.
Conduction and radiation (in heat transfer) only require a working understanding of algebra and calculus for the basic problems. More advanced problems will require a working knowledge of multivariable calculus.
The most difficult problems I solved in fluid dynamics required a BASIC understanding of multivariable calculus, and that was all.
Typically, statics and dynamics (courses) don't have anything to do with either, as typically those courses deal with simple systems, like what you're used to dealing with in physics (pulleys, rotating systems, friction, force balances, etc.) Don't worry about taking them if you're comfortable with the math I mentioned above.
Related to Fluid mech. and heat transfer prereq.
1. What is the purpose of studying fluid mechanics and heat transfer?
Studying fluid mechanics and heat transfer is important because it helps us understand the behavior of fluids (liquids and gases) and how they interact with their surroundings. This knowledge is crucial in many fields such as engineering, meteorology, and medicine.
2. What are some real-life applications of fluid mechanics and heat transfer?
Fluid mechanics and heat transfer have many practical applications, such as designing efficient cooling systems, predicting weather patterns, and developing medical equipment like ventilators and blood pumps.
3. What are some key concepts in fluid mechanics and heat transfer?
Some important concepts in fluid mechanics include viscosity, Bernoulli's principle, and the Navier-Stokes equations. In heat transfer, key concepts include conduction, convection, and radiation.
4. What are the prerequisites for studying fluid mechanics and heat transfer?
The prerequisites for studying fluid mechanics and heat transfer usually include a strong foundation in mathematics (calculus, differential equations) and physics (mechanics, thermodynamics). Some knowledge of chemistry may also be helpful.
5. How can understanding fluid mechanics and heat transfer benefit society?
Understanding fluid mechanics and heat transfer can lead to advancements in technology, medicine, and environmental protection. It can also help us address global issues such as climate change and energy sustainability.
  • STEM Academic Advising
  • Mechanical Engineering
  • General Engineering
  • Differential Equations
