Zarathuztra
- 36
A velocity field is given by [itex]\vec{V}[/itex]= [Ax[itex]^{3}[/itex] + Bxy[itex]^{2}[/itex]][itex]\hat{i}[/itex] + [Ay[itex]^{3}[/itex] + Bx[itex]^{2}[/itex]y][itex]\hat{j}[/itex]; A=0.2 m[itex]^{-2}[/itex]s[itex]^{-1}[/itex], B is a constant, and the
coordinates are measured in meters. Determine the value and
units for B if this velocity field is to represent an incompressible
flow. Calculate the acceleration of a fluid particle at point
(x, y)=(2, 1). Evaluate the component of particle acceleration
normal to the velocity vector at this point.
u=[itex]\frac{\partial\Psi}{\partial y}[/itex] v=-[itex]\frac{\partial\Psi}{\partial x}[/itex]
I used the above equation to get value equations u and v, there is something I'm missing, a bit of reasoning that has to be made using the given information to determine a constraint that exists since the fluid is incompressible. This should link the rates of change to each other. But that's where I get stuck, having trouble hanging on to all the concepts..
u = [2Bxy][itex]\hat{i}[/itex] + [.6y[itex]^{2}[/itex] + Bx[itex]^{2}[/itex]][itex]\hat{j}[/itex]
v = -[.6x[itex]^{2}[/itex] + By[itex]^{2}[/itex]][itex]\hat{i}[/itex] - [2Bxy][itex]\hat{j}[/itex]
Assumptions:
1. Incompressible flow
2. B is constant
