Fluid Mechanics: Differential Hg Manometer
In summary, a differential mercury manometer is used to measure the pressure in pipe A, which contains gasoline with a specific gravity of 0.65, and pipe B, which contains water. The question asks for the differential reading, h, when pipe A has a pressure of 20 kPa and pipe B has a vacuum of 150 mm Hg (equivalent to 610 mm Hg absolute pressure). The distance from the fill line in pipe A to the manometer is 0.3 m, and the distance from the fill line in pipe B to the manometer is also 0.3 m.
nicmat42
A differential mercury manometer is connected to pipe A containing gasoline (SG=0.65), and to pipe B containing water. Determine the differential reading, h, corresponding to a pressure in A of 20kPa and a vacuum of 150 mm Hg in B.
Distance from pipe A to fill line is 0.3 m and distance from pipe B to other fill line is 03 m.
I have done a few manometer problems before, however, I am not sure what to make of the "vacuum of 150 mm Hg in B". I do not know what this is implying to the problem?
If someone could kindly explain I would be very grateful and will be able to complete the question.
Thanks
It sounds like they are talking about the pressure relative to 1 atm (760 mm Hg).
So the "vacuum of 150 mm Hg" means an absolute pressure of (760-150) or 610 mm Hg.
This probably means the 20 kPa pressure is really 1 atm + 20 kPa.
I would approach this problem by first clarifying the meaning of "vacuum of 150 mm Hg in B". In this context, vacuum refers to a region of low pressure. So, in B, there is a pressure of -150 mm Hg (negative because it is lower than atmospheric pressure). This information is important because it affects the calculation of the differential reading in the manometer.
To solve this problem, we can use the equation for pressure difference in a manometer: P1-P2 = ρgh, where P1 and P2 are the pressures in the two pipes, ρ is the density of the fluid (mercury in this case), g is the acceleration due to gravity, and h is the height difference between the two arms of the manometer.
First, we need to calculate the pressure in pipe A, which is given as 20 kPa. We can convert this to mm Hg by multiplying by 760 (since 1 mm Hg = 1 torr = 1/760 atm). So, P1 = 20 kPa * 760 mm Hg/kPa = 15200 mm Hg.
Next, we need to calculate the pressure in pipe B. Since there is a vacuum of -150 mm Hg, the pressure in B is equal to atmospheric pressure (760 mm Hg) minus the vacuum (-150 mm Hg). So, P2 = 760 mm Hg - (-150 mm Hg) = 910 mm Hg.
Now, we can plug these values into the manometer equation: 15200 mm Hg - 910 mm Hg = ρgh. We know the density of mercury (ρ) and the height difference (h) between the two arms of the manometer (0.3 m - 0.3 m = 0), so we can solve for the differential reading, h.
h = (15200 mm Hg - 910 mm Hg) / (13600 kg/m^3 * 9.8 m/s^2) = 1.11 meters.
Therefore, the differential reading in the manometer is 1.11 meters. This means that the level of mercury in the arm connected to pipe A will be 1.11 meters higher than the level in the arm connected to pipe B.
FAQ: Fluid Mechanics: Differential Hg Manometer
What is a Differential Hg Manometer and how does it work?
A Differential Hg Manometer is a device used to measure the difference in pressure between two points in a fluid system. It consists of a U-shaped tube filled with mercury and attached to the system at two different points. The difference in pressure between the two points causes the mercury levels in the two arms of the tube to change, allowing for the pressure difference to be calculated.
How accurate is a Differential Hg Manometer?
The accuracy of a Differential Hg Manometer depends on several factors such as the quality of the instrument, the skill of the operator, and the conditions of the fluid being measured. Generally, it has a high level of accuracy and is commonly used in scientific and industrial settings for precise pressure measurements.
What are the advantages of using a Differential Hg Manometer?
One of the main advantages of a Differential Hg Manometer is its ability to measure small pressure differences accurately. It is also a simple and inexpensive device, making it a popular choice for many applications. Additionally, it does not require a power source or calibration, making it easy to use in various settings.
Are there any safety concerns when using a Differential Hg Manometer?
Yes, there are some safety concerns when using a Differential Hg Manometer. Mercury is a toxic substance, and precautions should be taken when handling it. The manometer should be handled carefully to avoid breakage, and any spills should be cleaned up immediately. It is also essential to dispose of the mercury properly according to local regulations.
What are some common applications of a Differential Hg Manometer?
A Differential Hg Manometer has many uses in various industries such as HVAC, chemical and pharmaceutical manufacturing, and fluid systems in automobiles and aircraft. It is also commonly used in laboratory settings for experiments and research involving fluid dynamics and pressure. Additionally, it is used in meteorology for measuring atmospheric pressure.
33K
