happyparticle
- 407
- 20
- Homework Statement
- Derivation of the Euler's equation using ##\frac{d}{dt} (\rho \vec{u} \otimes \vec{u}) = \phi + F_v + F_s##
- Relevant Equations
- ##\frac{d}{dt} (\rho \vec{u} \otimes \vec{u}) = \phi + F_v + F_s##
Euleur's equation:
##\frac{D\vec{u}}{Dt} = \frac{-\nabla P + \vec{g}}{\rho}##
For a volume fixed in space with the positive component of the z axis pointing up, I have the force of gravity pointing down.
Using the following equation I have to derive the Euler's equation.
Where ##\phi## is the flux, ##F_v## and ##F_s ## are the volume and surface forces.
I think that the flux moving outside of the volume is:
##- \oint_S \rho \vec{u} \otimes \vec{u} dS ##
Also, since the force of gravity is a volume force
##F_v = \rho V \vec{g}##
and
##F_s = \oint_S (-P \hat{n}) dS## is the pressure on the surfaces, pointing outside of the volume.
So far I have
##\frac{d}{dt} (\rho \vec{u} \otimes \vec{u}) = - \oint_S \rho \vec{u} \otimes \vec{u} dS + \rho V \vec{g} + \oint_S (-P \hat{n}) dS##
I'm wondering if I'm right. Also, I'm not sure which component of the pressure should I keep.
For instance, for a cylinder where the surface S is the top, where the flux is measured. I think I could consider only the z components of both the pressure and gravity.
In this case, I would have ##F_s = \oint_S (-P \hat{n}) \cdot \hat{z} dS## and ##F_v = \rho V g \hat{z}##.
and
So far I have
