Fluid mechanics help mechanical engineering
In summary: P = τω, where P is the power, τ is the torque, and ω is the angular velocity. Substituting the values we have, we get:P = (37.7)(314.16) = 11840 WattsIn summary, to solve these problems, we used the Casson plastic fluid model to relate shear stress, shear rate, and apparent viscosity. We also used the formula for torque and power to calculate the values required in the second question. I hope this helps you with your understanding of fluid mechanics.
apamnani1
Fluid mechanics help! mechanical engineering
Hi all,
I've answered a page of questions from a engineering textbook by mike tooley but I'm really struggling on these two questions.
1) A Casson plastic fluid is subjected to a shear force of 5.5 Pa. If the fluid obeys a law of the form T =1.5 +0.2^0.45u, determine the shear rate and apparent viscosity under these conditions
2) Oil of dynamic viscosity 0.12 Nsm-2 is used to lubricate the space between the plain journal bearing with the shaft. The shaft and bearing are concentric and the space between them is filled with an oil of dynamic viscosity of 0.15Nsm^-2.
Determine the torque required to overcome viscous resistance and the power loss when the shaft is rotating at a speed of 3000rpm.
Any help would be great.
Thanks!
Hello there,
As a scientist with expertise in fluid mechanics, I can assist you with these questions. Let's start with the first one:
1) To solve this problem, we can use the Casson plastic fluid model, which relates the shear stress (T) to the shear rate (u) and apparent viscosity (μ) through the equation T = μu^0.45. We are given T = 5.5 Pa and the law of the form T = 1.5 + 0.2^0.45u. Substituting these values into the equation, we get:
5.5 = 1.5 + 0.2^0.45u
4 = 0.2^0.45u
u = (4/0.2^0.45) = 76.72 s^-1
To find the apparent viscosity, we can rearrange the Casson plastic fluid model equation to μ = T/u^0.45. Substituting the values we have, we get:
μ = 5.5/76.72^0.45 = 0.109 Pa s
Therefore, the shear rate is 76.72 s^-1 and the apparent viscosity is 0.109 Pa s for this Casson plastic fluid under the given conditions.
Moving on to the second question:
2) To determine the torque required to overcome viscous resistance, we can use the formula τ = μA(dv/dx), where τ is the shear stress, μ is the dynamic viscosity, A is the area of contact, and dv/dx is the velocity gradient. In this case, A and dv/dx are constant since the shaft and bearing are concentric, so we can simplify the equation to τ = μv, where v is the velocity of the shaft.
We are given that the dynamic viscosity of the oil is 0.12 Nsm^-2 and the shaft is rotating at 3000 rpm. To convert rpm to radians per second, we multiply by 2π/60. So, the velocity of the shaft is:
v = (3000*2π/60) = 314.16 rad/s
Substituting this value and the dynamic viscosity into the equation, we get:
τ = (0.12)(314.16) = 37.7 Nm
This is the torque required to overcome viscous resistance. To find the
Related to Fluid mechanics help mechanical engineering
1. What is fluid mechanics?
Fluid mechanics is a branch of physics that deals with the study of fluids (liquids and gases) at rest and in motion. It involves the application of mathematical equations and principles to analyze the behavior and properties of fluids, such as flow rate, pressure, and viscosity.
2. How is fluid mechanics relevant to mechanical engineering?
Fluid mechanics is essential in mechanical engineering as it helps in the design and analysis of machines and systems that involve the flow of fluids. This includes pumps, turbines, pipes, and heat exchangers, among others. Understanding fluid mechanics is crucial for mechanical engineers to optimize the performance and efficiency of these systems.
3. What are some common applications of fluid mechanics in mechanical engineering?
Some common applications of fluid mechanics in mechanical engineering include the design of hydraulic systems for heavy machinery, the analysis of aerodynamic forces in aircraft and vehicles, and the optimization of cooling systems in engines and industrial processes. Fluid mechanics is also used in the design of pumps, compressors, and valves for various industrial and commercial applications.
4. What are some fundamental principles of fluid mechanics?
Some fundamental principles of fluid mechanics include the continuity equation, which states that the mass of fluid entering a system must equal the mass of fluid leaving the system; Bernoulli's equation, which describes the relationship between fluid pressure, velocity, and elevation; and Newton's laws of motion, which govern the behavior of fluids in motion.
5. How can fluid mechanics be applied to solve real-world engineering problems?
Fluid mechanics is used to solve real-world engineering problems by applying mathematical equations and principles to analyze and predict the behavior of fluids in various systems. By understanding the properties and behavior of fluids, engineers can design and optimize systems for different applications, such as improving the efficiency of pumps or reducing drag on vehicles. Fluid mechanics is also crucial in the development of new technologies, such as alternative energy sources and environmental protection systems.
  • STEM Academic Advising
