Fluid mechanics of water in a pipe
In summary: I feel like I'm not applying it correctly. The Bernoulli equation should look more like this: 1/2*ρ*v1² + P1 = 1/2*ρ*v2² + P2
saytrain15
Hello All,
I've frequented this forum for various purposes and this is the first time I've decided to post! Hopefully I can find the help or conformation I'm looking for. I may not have all the necessary info, but I feel this is basic enough that I should be able to come up with an appropriate answer.
This is a basic setup where I have water being pumped through steel piping and I'm trying to find the exit pressure and velocity of the water. Here is what I know for sure.
Pipe Diameter, d = .151in or .003835m
Pipe Length, l = 72in or 1.8288m
Pressure from pump, P = 100psi or 689400Pa
Temp, T = 140°F or 60°C
Density, ρ = 983.2 kg/m³
Viscosity, μ = 0.467*10-³ N*s/m²
Roughness steel, ε = .000025 m
Now somewhere in here I feel I am going about this wrong, so please bear with me.
1. To get the velocity of the water at the starting point I use Bernoulli's equation for dynamic pressure, q=1/2*ρ*v². Solving for v, I get v=37.45 m/s.
2. I calculate my Reynolds Number and relative roughness of the steel pipe, then use the Moody chart to determine the Friction Factor.
Re = (ρ*v*d)/μ = (983.2*37.45*.003835)/(.467*10-³) = 301,978
RR = ε/d = (.000025)/(.003835) = .00652
From the Moody chart: f = .031
3. Calculating the pressure drop due to the friction in the pipe (I feel this is my problem)
ΔP= (ρ*v²*f*l)/(2*d) = (983.2*37.45²*.031*1.8288)/(2*.003835) = 10192437.5 Pa
From there I would use Bernoulli's equation for the flow at the beginning of the pipe, P + 1/2*ρ*v² + ρ*g*h (last part is negligible for me), set equal to an equation for the exit flow which incorporates the friction.
I feel as though I am making an incorrect assumption (or 2 or 3...) which is leading to such a large drop in pressure. Areas I feel I could have gone astray; calculating the initial velocity using the dynamic pressure equation, assuming that friction will even have an effect here, or even that the pressure of the pump is way too high for such a small diameter pipe (and my calculations are somewhat correct).
If there is anyone out there that can comment on this and perhaps guide me in the right direction I'd greatly appreciate it.
Cheers and thanks for reading!
Yikes... I was going to use Poiseuille flow, but your Re >>2000, so that's no good.
The exit is at atmospheric pressure...does the pipe let water freely squirt out, or is it held at some other pressure? That gives you your pressure drop across the length of the pipe.
100 psi into a 1/10 inch diameter tube... yikes.
Yea, I'm way past laminar flow with the current setup. I'm looking into more details right now, but I'm pretty sure there is not a resovoir at the end of the tubing and there is not any kind of nozzle (which would probably shoot off like a bullet anyways).
After looking at it for a bit I too started to think that the 100 psi was just way too much. Thank you for your reply, it had been some time since I dealt with fluid mechanics and I needed some one else's opinion on this.
Before I keep digging into this topic, can anyone confirm that the way in which I used the dynamic pressure equation, q = 1/2*ρ*v², was in fact correct? I thought it to be since the only initial pressure in the system is from the pump, but I'd really like to know that I do infact have the basics correct.
Your velocity is probably closer to 9 meters per second. Reynolds number is about 36.000. See thumbnail.
Bob S
Bob,
I was wondering how you came to the conclusion that the initial velocity would be around 9 m/s. Assuming everything is correct, pressure drop = 108 psi and pressure of water at the exit = 7.45 psi, I can plug those numbers into the bernoulli equation, which should look like this:
and with the numbers:
1/2*983*(9)² + 792810(pascals) = 1/2*983*(v2)² + 51705(pascals)
solving for v2 = 39.86 m/s²
I know that a drop in pressure leads to increased velocity typically where the flow path has decreased in area, but I'm not positive that the same applies when the drop in pressure is due to head loss or the friction in the pipe.
Also, I'm still looking for confirmation on how to calculate an initial velocity with the given data. Need to be sure I have the basic of basics down before I'm satisfied with the other results. Once again, any help is appreciated! Cheers!
After going through everything again, I realize I'm completely off base in my last post. That program Bob used gave me my output velocity via the flow rate. If that's the case, then my exit velocity is roughly 0.06 m/s. To me that seems much too low. I am wandering off the path somewhere and making poor assumptions.
Still interested in how to determine my initial velocity though.
Your initial steps in the OP (steps 1 through 3) are fine. But once you got to step 3 and found your pressure drop is much larger than the actual pressure drop, you need to iterate. Go back and reduce velocity, then recalculate pressure drop. Keep doing that till you home in on the velocity required to produce the pressure drop you know to exist. Once you find the velocity, you can determine flow rate.
You might also look through the text I've posted online https://www.physicsforums.com/showthread.php?t=234887"called "Pipe-Flo Pro.PDF".
Note that you don't need to use the Bernoulli equation unless there is a change in elevation or change in pipe diameter. Since you don't mention a change in either of those, the only pressure drop is the permenant, irreversible loss caused by pipe friction and calculated by the Darcy-Weisbach equation. To see how to incorporate velocity or elevation changes, see equation 15 and 16 on page 14 of the Pipe-Flo Pro.PDF file.
Related to Fluid mechanics of water in a pipe
1. What is the Bernoulli's equation and how does it apply to fluid mechanics in a pipe?
The Bernoulli's equation is a fundamental principle in fluid mechanics that states that the sum of all forms of energy in a fluid flowing through a pipe is constant. This means that as the velocity of the fluid increases, the pressure decreases and vice versa. This equation is commonly used to analyze the flow of water in pipes and can help predict the behavior of the fluid.
2. What factors affect the flow rate of water in a pipe?
The flow rate of water in a pipe is affected by several factors such as the diameter of the pipe, the viscosity of the fluid, the pressure difference between the two ends of the pipe, and the length of the pipe. Additionally, the roughness of the pipe's inner surface and any obstructions or bends in the pipe can also impact the flow rate.
3. How is the pressure in a pipe affected by the depth of the water?
The pressure in a pipe is directly proportional to the depth of the water. This means that as the depth of the water increases, so does the pressure. This is due to the weight of the water above pushing down on the water at the bottom of the pipe. This relationship is known as Pascal's law and is a key concept in understanding the behavior of fluids in pipes.
4. What is the difference between laminar and turbulent flow in a pipe?
Laminar flow occurs when the fluid moves in smooth, parallel layers, with little to no mixing between the layers. This type of flow is characterized by low velocities and a well-defined flow pattern. On the other hand, turbulent flow occurs when the fluid moves in an irregular and chaotic manner, with mixing between the layers. This type of flow is associated with higher velocities and is often seen in pipes with rough inner surfaces or when the flow rate is high.
5. How do you calculate the velocity of water in a pipe?
The velocity of water in a pipe can be calculated using the continuity equation, which states that the product of the cross-sectional area of the pipe and the velocity of the fluid is constant. This means that if the cross-sectional area decreases, the velocity must increase and vice versa. In practical applications, the velocity can also be measured using devices such as flow meters or by timing how long it takes for a known volume of water to pass through a specific point in the pipe.
15K
  • General Engineering
  • Mechanical Engineering
