Fluid Mechanics: Point like sink
In summary, the problem involves a hypodermic needle being pulled up at a constant speed. The solution involves drawing a sphere around the tip of the needle and using the equation of continuity to determine the speed field, v(r), in the surrounding fluid. The indefinite integral is used to find the total volume flow rate and the 4pi(r^2) represents the surface area of the sphere. The speed of the fluid is constant and decreases as the radius increases. The integration is over the surface of the sphere to determine the volume flow rate through that surface.
kingwinner
1,270
Fluid Mechanics: Point like "sink"
I am badly badly confused by the following problem and its solution. I hope that someone would be kind enough to help me out! Thank you for your help and your time!:smile:
1) The plunger of a hypodermic needle (a point-like "sink") is being pulled up with speed v_p as shown in the first link/picture. The fluid at the needle is v_n given by the equation of continuity. What is v(r), the speed field, in the surrounding fluid? (Hint: draw a sphere of radius r centered at the tip of the needle)
http://www.geocities.com/asdfasdf23135/phy002.JPG
The model solution is:
http://www.geocities.com/asdfasdf23135/phy003.JPG
NOTE: Q is the volume flow rate.
And I am completely lost after raeding this solution. I don't understand a single step from the beginning to the end.
(i) What is the REASON of drawing a sphere around the tip of the needle?
(ii) Why is it true that dQ=v(r)dA? What I have learned is that Q=vA, not dQ=v(r)da.
(iii) What is dA?
(iv) Why did they take the indefinite integral to both sides?
(v) How come v(r) is brought OUT of the integral sign? v(r) should be varying and is NOT (vi) a constant, right?
(vii) How actually did they get the 4pi(r^2) out of nowhere?
(viii) Is the origin r=0 set to be at the centre of the sphere (i.e. the tip of the needle)? What does v(1) represent, for example?
(ix) v_p and v_n are not used in any part of the model solution. Does it mean that the speed fluid given by v(r)=Q/(4*pi*r^2) would exist even if the plunger is stationary (i.e. not pulled)? How is this possible? Shouldn't the surrounding fluid be STATIC?
(x) One more question: when it says that the plunger is being pulled up at speed v_p, but this is not the speed of the FLUID. Then how can it be related to the equation of continuity? Is it true that the fluid below the plunger but above the top of the needle is ALSO moving up at speed v_p? If so, why?
I apologize for the amount of questions being asked, but any help to any part of the problem is greatly appreciated!
i. Because outside the needle, the motion of fluid flowing into its tips is symmetric
"spherically". If you draw a sphere... the speed of fluid flow is same every where on the
surface of the sphere, regardless of its radii...
ii. Because v(r) is constant by part (i), differential what you have learned i.e. Q=vA yeild
dQ = v(r) dA
iii. An arbitrary infinitely small area on the surface of sphere...
iv. Becuase we want the total volume Q... but dQ is only part of it... therefore, we do an integration
v. It is a constant by part (i)
vii. This is the surface area of a sphere... if you integrate over dA, you get the total
surface area of the sphere, which is 4pi r^2...
viii Yes, v1 is the volume flow rate over area of the fluid at r = 1.
ix. No, Q is depend on v_p, the larger the v_p, the more fluid is sucked into the needle...
your solution just didn't show there relationship
x. v_p and v_n is related by the cross-section area... obviously, v_p * A_p = v_n * A_n...
(A_x is their cross section area respectively)... and by definition, Q is how much fluid
being sucked by the needly, therefore, Q = v_n * A_n
What the integration is describing is the volume flow rate through the surface of spheres centered around the tip of the needle.
If one starts with a small sphere centered around the tip of the needle the water will flow throught the surface of the sphere towards this region of low pressure. Since the local pressure is the same in all directions the sphere will collapse at the same rate along all directions to fill the void created by the water that entered the needle.
The volume flow rate throught the surfaces of successively larger spheres will be constant - that is the whole of the liquid is "falling" inwards towards the tip of the needle. This does not mean that v(r) will be constant since as the surface area increases the rate of flow decreases to keep the total volume flow rate constant. That is v(r) will be a decreasing function with increasing r.
To come back to the integration - what it is determining is the volume flow rate through the surface of a particular sphere. The integration is therefore over the surface of the sphere. The flow rate through a small portion of the sphere will then be per definition given by
[tex]dQ = v(r) dA[/tex]
Thanks for explaining! I have to think about all of these before possibly making another reply!
FAQ: Fluid Mechanics: Point like sink
What is fluid mechanics?
Fluid mechanics is a branch of physics that studies the behavior of fluids (liquids and gases) when they are in motion or at rest. It involves the study of properties such as velocity, pressure, and density of fluids, and how forces and energy affect their motion.
What is a point like sink in fluid mechanics?
A point like sink is a hypothetical concept used in fluid mechanics to represent a small, localized area where fluid is flowing towards a central point or singularity. It is used to study the behavior of fluids in certain scenarios, such as when there is a small hole at the bottom of a container or in the center of a whirlpool.
How does a point like sink affect the flow of fluid?
A point like sink causes fluid to flow inwards towards the center, creating a vortex or a swirling motion. This is due to the conservation of mass principle, where as fluid flows towards the center, it must also flow outwards to maintain a constant volume. The speed of the fluid increases as it gets closer to the center of the sink.
What are some real-life examples of a point like sink?
Some real-life examples of a point like sink include the drain of a sink or bathtub, the eye of a hurricane, and the center of a tornado. These are all situations where fluid is flowing towards a central point, creating a vortex-like motion.
How is fluid mechanics used in everyday life?
Fluid mechanics has many practical applications in everyday life, such as in the design of pumps, turbines, and other hydraulic machines. It is also used in the study of weather patterns and ocean currents, and in the development of transportation systems such as airplanes and ships. In addition, fluid mechanics plays a crucial role in the fields of chemical engineering, environmental science, and biomechanics.
