eyraincg
- 2
Fluid Mechanics Question -- Pipes and Pumps
Design a system to deliver [itex]1 m^{3}/s[/itex] of water from reservoir A at elevation 300m to reservoir B at 500m. The distance from A to B is 1000km (1000,000m) and the elevation between the two reservoirs can be approximated as parabolic with a maximum elevation of 660m reached 600km from A.
Negative pressures shouldn’t be allowed to exceed about 70% of atmospheric pressure, use this figure to prevent cavitation.
The steel pipe with a roughness of e=0.5cm and diameter of 1.1m and a pressure rating of 150m head is available. The pumps can deliver [itex]1m^3/s[/itex] at 100m head.
*Since the horizontal distance is significantly greater than the vertical distance. I approximated the parabola with straight lines from A to the maximum point of 600,000m from A and elevation 660m and then from that point to B.
I am then doing calculations separately for the 2 parts
*I am trying to calculate amount of pumps that would make this system work and prevent cavitation
*Any help would be appreciated, thanks!
Extended bernoulli’s equation:
[itex]\frac{V_{1}^{2}}{2g}[/itex] + [itex]\frac{p_{1}}{\gamma}[/itex] + [itex]Z_{1}[/itex] + [itex]h_{p}[/itex] = [itex]\frac{V_{2}^{2}}{2g}[/itex] + [itex]\frac{p_{2}}{\gamma}[/itex] + [itex]Z_{2}[/itex] + [itex]h_{L}[/itex]
V: Velocity
P: Pressure
[itex]\gamma[/itex]: Specific Weight
Z: Height/ Altitude
[itex]h_{p}[/itex]: Pump Head
[itex]h_{L}[/itex]: Head Loss
Head Loss:
[itex]
h_{L} = f \frac{L}{D} \frac{V^{2}}{2g}
[/itex]
f: friction factor
L: Pipe Length
D: Pipe Diameter
Volumetric flow rate to Velocity:
V = Q/A
Q: Volumetric Flow Rate[itex] (m^{3}/s)[/itex]
A: Area
V = Velocity
For part 1 [0km to 600km] only:
D = 1.1m
A = 0.95 m^{2}
Q = 1[itex]m^{3}/s[/itex]
V = [itex]\frac{Q}{A}[/itex] = 1.053 m/s
f = 0.0171 (from moody diagram)
R[itex]_{e}[/itex] = 1157490
P[itex]_{minimum}[/itex] (absolute) = 101315Pa*0.7 = 70927.5Pa
P[itex]_{minimum}[/itex] (gage) = P_{min,absolute} – P_{atmospheric} = -30397.5Pa
H[itex]_{p}[/itex] = 100m
L ~= 600km = 600,000m
Using Bernoulli’s formula solve for maximum Length before cavitation:
[itex]\frac{V_{1}^{2}}{2g}[/itex] + [itex]\frac{p_{1}}{\gamma}[/itex] + Z[itex]_{1}[/itex] + h[itex]_{p}[/itex] = [itex]\frac{V_{2}^{2}}{2g}[/itex] + [itex]\frac{p_{2}}{\gamma}[/itex] + Z[itex]_{2}[/itex] + [itex]h_{L}[/itex]
P[itex]_{1}[/itex] = 0
P[itex]_{2}[/itex] = -30397.5
V[itex]_{1}[/itex] = V[itex]_{2}[/itex]
Z[itex]_{1}[/itex] = 300m
Z[itex]_{2}[/itex] = 660m
[itex]\gamma[/itex] = 9800
Sub in Head Loss:
[itex]\frac{V_{1}^{2}}{2g}[/itex] + [itex]\frac{p_{1}}{\gamma}[/itex] + Z[itex]_{1}[/itex] + h[itex]_{p}[/itex] = [itex]\frac{V_{2}^{2}}{2g}[/itex] + [itex]\frac{p_{2}}{\gamma}[/itex] + Z[itex]_{2}[/itex] + [itex]f*\frac{L}{D}*\frac{V^{2}}{2g}
[/itex]
Rearrange:
L = [itex](\frac{V_{1}^{2}}{2g}[/itex] + [itex]\frac{p_{1}}{\gamma}[/itex] + Z[itex]_{1}[/itex] – Z[itex]_{2}[/itex] + h[itex]_{p}[/itex] - [itex]\frac{V_{2}^{2}}{2g}[/itex] - [itex]\frac{p_{2}}{\gamma}[/itex] ) [itex]*\frac{2D*g}{fV^{2}}[/itex]
Cancelling terms:
L = (Z[itex]_{1}[/itex] – Z[itex]_{2}[/itex] +h[itex]_{p}[/itex] - [itex]\frac{p_{2}}{\gamma}[/itex]) [itex]*\frac{2D*g}{fV^{2}}[/itex]
L = (300m – 660m + 100m +3.0986) *1144.77
L = -293076m
I don’t understand why this is the answer, what am I doing wrong?
V: Velocity
P: Pressure
Z: Height/ Altitude
Head Loss:
[itex]
[/itex]
f: friction factor
L: Pipe Length
D: Pipe Diameter
V = Q/A
A: Area
V = Velocity
D = 1.1m
A = 0.95 m^{2}
Sub in Head Loss:
[/itex]
Rearrange:
Cancelling terms:
L = -293076m
