Fluid Mechanics question,velocity potential
In summary, in a theoretical exposition of the velocity/force potential, the external force acting on each point of the fluid and the speed are derived from a scalar and admit a potential. The acceleration depends on the coordinates of the point and time, and can be expressed as a compound function. By substituting the partial derivatives of the velocity/force potential for the velocities in the expression for acceleration, the desired expression can be obtained.
dx+dy
I am new in this place, am studying civil engineering in Spain,Madrid, and is something I do not understand in a theoretical exposition of the velocity/force potential.
They suppose that the external force that it acts in each point of the fluid and the speed, derive from scalar , so they admit a potential :
[tex]\frac{\vec{F}}{m}= - \vec{\nabla} U[/tex]
[tex]\vec{V}= \vec{\nabla} \Omega[/tex]
If the acceleration depends on the coordinates of the point and the time [tex]\vec{a} ( u',v',w') = f(x,y,z,t)[/tex] :
[tex]u'= \frac{du}{dt}= \frac{\partial u}{\partial x} \frac{\partial x}{\partial t} +\frac{\partial u}{\partial y } \frac{\partial y}{\partial t} + \frac{\partial u}{\partial z}\frac{\partial z}{\partial t} + \frac{\partial u}{\partial t}[/tex] and thus with the other coordinates of the acceleration
And here my doubt comes, I do not understand as they obtain to this expression:
[tex]u'= \frac{\partial^2 \Omega}{\partial x^2} \frac{\partial \Omega}{\partial x} +\frac{\partial^2 \Omega}{\partial x \partial y} \frac{\partial \Omega}{\partial y} + \frac{\partial^2 \Omega}{\partial x \partial z}\frac{\partial \Omega}{\partial z} + \frac{\partial^2 \Omega}{\partial x \partial t}[/tex]
if somebody can help to understand it me, would be thanked for. Thank you very much
First of all, don't use partials where they don't belong!
Now, we have
[tex]\frac{dx}{dt}=u,\frac{dy}{dt}=v,\frac{dz}{dt}=w[/tex]
Thus, we may write the expression for the acceleration in the x-direction, i.e, u' as:
[tex]u'=u\frac{\partial{u}}{\partial{x}}+v\frac{\partial{u}}{\partial{y}}+w\frac{\partial{u}}{\partial{z}}+\frac{\partial{u}}{\partial{t}}[/tex]
Now, insert:
[tex]u=\frac{\partial\Omega}{\partial{x}},v=\frac{\partial\Omega}{\partial{y}},w=\frac{\partial\Omega}{\partial{z}}[/tex]
See if you get it right now!
Compound functions always was my nightmare[tex]\frac{\partial}{\partial t} \left(\frac{\partial \Omega}{\partial x}\right)=\frac{\partial}{\partial x} \left(\frac{\partial \Omega}{\partial x}\right) \underbrace{\frac{dx}{dt}}_{u}+\frac{\partial}{\partial y} \left(\frac{\partial \Omega}{\partial x}\right) \underbrace{\frac{dy}{dt}}_{v} + \frac{\partial}{\partial z} \left(\frac{\partial \Omega}{\partial x}\right) \underbrace{ \frac{dz}{dt}}_{w}+ \frac{\partial}{\partial t} \left(\frac{\partial \Omega}{\partial x}\right) \frac{dt}{dt}[/tex]
that is what it did not see, thank you very much to solve the doubt to me
FAQ: Fluid Mechanics question,velocity potential
What is fluid mechanics?
Fluid mechanics is a branch of physics that deals with the study of fluids (liquids and gases) and their behavior under various conditions. It involves the study of how fluids move, and the forces that act on them.
What is the definition of velocity potential?
The velocity potential is a concept in fluid mechanics that describes the relationship between the velocity of a fluid and its potential energy. It is a scalar function that represents the potential for fluid particles to move in a particular direction.
How is velocity potential related to fluid flow?
The velocity potential is directly related to fluid flow as it helps to determine the direction and magnitude of the fluid's velocity at any point in space. It is used in the calculation of streamlines, which are imaginary lines that represent the flow of a fluid.
What are some applications of velocity potential in fluid mechanics?
Velocity potential has various applications in fluid mechanics, such as in the study of laminar and turbulent flow, the design of pumps and turbines, and the analysis of aerodynamics. It is also used in the field of oceanography to study the movement of ocean currents.
How is the velocity potential calculated?
The velocity potential is calculated using the Laplace equation, which relates the rate of change of the velocity potential to the rate of change of the fluid's velocity. This equation can be solved using mathematical techniques such as separation of variables and boundary value problems.
