Fluid Mechanics Help: Questions Answered
In summary: So the pressure difference (Pa-(rho of pipe liquid in that leg)) cancels out because the pressure on both sides of the manometer is the same.In summary, 1. In Bernoulli's theorem, it basically states the if we have an ideal liquid (Newtonian) undergoing steady flow,wherever the velocity increases,the pressure of the liquid decreases.2. In an inverted differential manometer, how do we find the pressure equation for equilibrium conditions of the maometer liquid?(I mean the net upward pressures on the manometric liquid is it's own weight,isn't it?)3. Generally,why do we use all these different kinds of manometers
Urmi Roy
753
fluid mechanics...
Hi,everyone.
I'm doing the second of my mechanical engineering course and I've been doing fluid mechanics lately...I have some questions...could some ony please help me with them?
1.In Bernoulli's theorem,it basically states the if we have an ideal liquid (Newtonian) undergoing steady flow,wherever the velocity increases,the pressure of the liquid decreases. Now,intuitively,does this mean "When the liquid starts flowing fast,it doesn't have the time to impose a pressure on the walls of the pipe because it's rapidly flowing away?"
2.in an inverted differential manometer,how do we find the pressure equation for equilibrium conditions of the maometer liquid?(I mean the net upward pressures on the manometric liquid is it's own weight,isn't it?)
3.Generally,why do we use all these different kinds of manometers...inverted differential manometer,upright differential manometer,etc.?Do they have any individual/specific functions?
4.We often use thermodynamic equations (like the steady flow Energy Equation) for even water and other liquids...but is this permissible?...because in liquids,we have to account for inter-molecular atraction,and cannot treat it as an ideal gas(which we always assume in thermodynamics).
I know you have been studying thermodynamics recently.
1) Bernoulli's theorem like the First Law is just another presentation the law of conservation of energy. If a fixed parcel of fluid (= a control volume) is moving faster, then since it has constant total energy it's potential energy (pressure) must drop to compensate for its increase in kinetic energy.
Time does not enter into it.
2)In a differential manometer, inverted or not, you have a tube of liquid with different pressures pushing in opposite directions across the ends of the fluid in each leg. This causes a difference in the positions (levels) of the fluid surfaces in the legs. The product of the difference in pressure times the tube (liquid) cross sectional area equals the weight of the manometer fluid displaced = manometer fluid density times the difference in level times the cross sectional area. So you can see the area of the tube cancels out.
3)Convenience at specific locations.
4)Thermodynamics applies to all substances, not just ideal gasses. Some theory is obviously not appropriate for some substances. The intermolecular forces affect the internal energy of the substance.
No,actually I didn't exactly mean time...it's more that the fluid doesn't bother to exert pressure anymore when it has greater velocity.(just trying to find a way to explain it to myself!)
Studiot said:
2)In a differential manometer, inverted or not, you have a tube of liquid with different ...So you can see the area of the tube cancels out.
Suppose the pressure in the pipe is Pa on one side,the net pressure in that leg of the manometer is Pa-(rho of pipe liquid in that leg)xgxheight ...similarly,on the other side,it's Pb-(rho of pipe liquid in that leg)xgxheight ...
Each of these is the net pressure of the pipe liquid on the manometric liquid...why do we use the minus sign in each of the expressions(in upright manometer,it's Pa+(rho of pipe liquid in that leg)xgxheight )...secondly,isn't the Pa-(rho of pipe liquid in that leg)xgxheight the weight of the manometric liquid in the respective column?
The fluid flowing in the pipe may not even be a liquid!
The weight of anything = volume times density.
It is the manometric liquid that is displaced by the pressure difference, so it is the weight of this displaced manometric liquid that we consider.
Draw a diagram and convince yourself.
Okay,so why is it Pa-(rho of pipe liquid in that leg)xgxheight ?
bernoulli's eqn does not state that wherever the velocity of fluid increases,the pressure of the fluid decreases. there is a gravity head too... so even if velocity increases in some direction then the pressure gradient may still be positive in that direction.
Related to Fluid Mechanics Help: Questions Answered
What is fluid mechanics?
Fluid mechanics is the study of how fluids (liquids and gases) behave and interact with each other and with solid objects. It involves principles of physics, mathematics, and engineering to understand and analyze the behavior of fluids in various situations.
What are the main properties of fluids?
The main properties of fluids are density, viscosity, pressure, and temperature. Density is the mass per unit volume of a fluid, and it determines how easily a fluid can be compressed. Viscosity is the measure of a fluid's resistance to flow, and it is affected by temperature and pressure. Pressure is the force per unit area applied by a fluid, and it is responsible for the movement of fluids. Temperature affects the density and viscosity of a fluid, which in turn affects its behavior.
What are the fundamental equations of fluid mechanics?
The fundamental equations of fluid mechanics are the continuity equation, the Navier-Stokes equations, and the energy equation. The continuity equation states that the mass flow rate into a control volume must equal the mass flow rate out of the same control volume. The Navier-Stokes equations describe the motion of a fluid and are based on the principles of conservation of mass, momentum, and energy. The energy equation is a statement of the conservation of energy for a fluid system.
What are some common applications of fluid mechanics?
Some common applications of fluid mechanics include the design of pumps, turbines, and other fluid machinery, the study of aerodynamics in aircraft design, and the analysis of blood flow in the human body. It is also used in industries such as oil and gas, chemical processing, and environmental engineering.
How can I improve my understanding of fluid mechanics?
To improve your understanding of fluid mechanics, you can start by building a strong foundation in mathematics and physics. It is also helpful to practice solving problems and studying real-life examples. Additionally, attending lectures and seeking resources such as textbooks, online courses, and tutorials can also enhance your understanding of this subject.
  • Mechanical Engineering
  • Classical Physics
