Undoubtedly0
- 98
I am confused about the some of the concepts behind fluid statics. Here is an example to illustrate this, using Pascal's barrel experiment.
Consider a cylindrical barrel with cross-sectional area A and height H. Now insert a straw of height h and cross-sectional area a so that the total of height of the barrel and straw is h + H. Assuming a fluid of uniform density ρ, the total weight of the fluid is
[tex] W = m_{tot}g = \rho V g = \rho g (ha + HA)[/tex]
If the barrel is sitting on a plank, then the magnitude of the normal force N of the plank on the barrel is simply N = W.
However, using a different method, I come up with a different result for N. By Pascal's equation, the gauge pressure at the bottom of the tank is
[tex] P_{bottom} = \rho g (h + H) [/tex]
Thus the force due to pressure acting on the bottom of the barrel is
[tex] F_P = P_{bottom}A = \rho g A (h + H) [/tex]
In order to balance this force, the normal force N from the plank on the barrel must thus be equal to FP, yet this is a different result then from before: N = W ≠ FP = N.
There must be some error in my reasoning here, but I cannot find it. Thanks a bunch for the help!
