roldy
- 237
- 2
So the other day I was thinking about this problem that arose when I was watching water spiral down a bowl shaped drain.
If you can imagine a spherical shell and on the inside there is a fluid stream that is tangent to the interior curvature of the wall. The entrance of the fluid stream is at some point (r,[tex]\theta[/tex], [tex]\phi[/tex]) where r is the inside radius of the sphere.
http://en.wikipedia.org/wiki/File:Coord_system_SZ_0.svg"
Question: What nozzle pressure would you need in order for the fluid to remain attached to the curved surface? Another question that follows is what nozzle pressure would you need in order for the fluid to travel fully around the circumference of the sphere? To make things simpler, I'm assuming the fluid to be an inviscid, Newtonian fluid with laminar flow. Now since I'm assuming an inviscid flow, the only other thing that would affect the travel of the fluid stream would be gravity. With inviscid flow, the friction between the wall and fluid stream would cause the fluid stream velocity to decrease as it goes around the circumference of the sphere, hence prohibiting the fluid from going all the way around the sphere.
I've tried to think of a way to model this with an equation using the Navier Stokes equations. I would like to solve for the pressure in terms of some diameter. Eventually I would like to perform a fluid simulation but first would like to perform a theoretical study. How should I approach this problem?
