Flux density inside and outside a coaxial cable.
In summary, the conversation discusses the correct working for calculating the magnetic field inside and outside a coaxial cable using the equations ∫B.dl = μI and B = (μI)/(2∏r). It also mentions the direction of current flow and the regions where the calculations are valid.
lam58
29
For question 4b in the problem sheet attached below, is my working correct for B outside and inside the coaxial cable?
Ans:
Outside coaxial:∫B.dl = μI (the integral is between 0 and 2∏r)
=> B = (μI)/(2∏r)
Inside the coaxial: [tex]\int_{2\pi a}^{2\pi r} B.dI[/tex]
= [tex] μI.\frac{a^2}{\pi r^{2}b^{2}}[/tex]
=> [tex]B[2\pi r - 2\pi a] = μI.\frac{a^2}{\pi r^{2}b^{2}}[/tex]
=>[tex]B = μI.\frac{a^2}{\pi r^{2}b^{2}} * \frac{1}{2\pi r - 2\pi a}[/tex]
It's not obvious what you mean by "outside the coaxial" ... do you mean "between the conductors"?
Notice that the inner current Ia is leftward, but the outer current Ib is rightward.
So, for r>b (outside the outer mesh), how much total I is piercing the Area?
It looks like your "inside the coaxial" is trying to be for r<a, that is, inside the inner conducting wire, assuming uniform current density. This region was not asked for in the problem (perhaps because the current density is not really uniform, in real situations). The region between a and b is filled with insulator, having zero current flow in it (so the right-hand side is constant non-zero).
Related to Flux density inside and outside a coaxial cable.
1. What is flux density inside and outside a coaxial cable?
Flux density refers to the amount of magnetic flux per unit area, and it is used to measure the strength of a magnetic field. In the case of a coaxial cable, flux density inside the cable refers to the strength of the magnetic field within the inner conductor, while flux density outside the cable refers to the strength of the magnetic field in the surrounding space.
2. How does the flux density inside and outside a coaxial cable affect signal transmission?
The flux density inside and outside a coaxial cable affects signal transmission by creating a balanced electromagnetic field within the cable, which helps to minimize interference and signal loss. The flux density outside the cable also helps to prevent external electromagnetic interference from affecting the signal.
3. What factors can affect the flux density inside and outside a coaxial cable?
The flux density inside and outside a coaxial cable can be affected by various factors, including the strength and direction of the current flowing through the cable, the distance between the inner and outer conductors, and the materials used for the conductors and insulation.
4. How can the flux density inside and outside a coaxial cable be measured?
The flux density inside and outside a coaxial cable can be measured using a gaussmeter, which is a device that measures magnetic flux density. The measurement is typically taken at various points along the length of the cable to ensure that the flux density is consistent throughout.
5. Can the flux density inside and outside a coaxial cable be changed?
Yes, the flux density inside and outside a coaxial cable can be changed by adjusting the current flow, the distance between the conductors, or the materials used for the conductors and insulation. However, it is important to maintain a balanced electromagnetic field to ensure optimal signal transmission and minimize interference.
  • Electromagnetism
