Flux integral of surface using Stokes theorem
In summary: Sorry, that doesn't make any sense to me.In summary, the student is trying to solve a surface integral problem, but is having difficulty understanding the calculations. The student is having trouble understanding the orientation of the curve when traversing it, which is causing errors in the calculations.
flaxstrax
I have to control stokes theorem( I have to calculate line-and surface integral.
I have a vectorfield a=(3y,xz,yz^2).
And surface S is a paraboloid 2z=x^2+y^2. And it is limited by plane z=2.
For line integral the line is a circle C: x^2+y^2=4 on the plane z=2.
Vector n is pointing down ( Outwards).
The line integral i got . it is -4*pi.
http://en.wikipedia.org/wiki/Stokes_theorem
Okay so i get these weird answers for surface integral and it should be -4 * pi.
I have done it in 5 different ways.
I find Flux a =(z^2-x,0,z-3) and then i find the n*dS. n*dS=-(f_x,f_y,1) = (x,y,-1) dx dy
Lets say that i use cylindrical coordinates , then x=r*cos t, y=r*sin t and z=z.
I find z = (x^2+y^2)/2 so it will be z=r^2/2
I think about the bonds , they should be 0 ≤ r ≤ 2 and 0 ≤ t ≤ 2*pi
Then i find the double integral →∬(z^2-x,0,z-3)*(x,y,-1) dx dy=
∬ z^2x-x^2-z+3 dS=
∬(r=0 to 2, t=0 to 2pi) r^4/4*r*r*cos t - r^2*r*(cos t)^2-r^2/2*r-3r dt dr =
∫(r=0 to 2) r^6/4 * sin t - r^3(t/2-1/2*cos t*sin t)-r^3/2*t+3rt dr=
∫(r=0 to 2) 0-r^3*pi - 0 - r^3* pi +6 r pi dr=
= ∫(r=0 to 2) -2*r^3* pi + 6*r*pi = -8*pi +12 * pi = 4 * pi
So i get 4 * pi from surface integral and -4*pi from line integral.
Can anyone explain what am i doing wrong ?
One thing that stands out is that in the diagram provided, the traversal of the curve is of the wrong orientation for applying Stokes'. This will generate an overall minus sign and could be the source of your error.
I don't understand what you mean ? Sorry, english is not my first language.
Actually, sorry the traversal is correct - ignore my last post.
∬ z^2x-x^2-z+3 dS=
It is correct to there. You have dropped a minus sign somewhere and trying to read that non-tex gives me eyestrain. The only term that should survive the ##\theta## integration is part of the ##\cos^2\theta## expression, and somewhere you lost the - in front of that term. It does come out ##=-4\pi##.
The boundary of the surface S is the circle ##x^2 + y^2 = 4##. However, this is also the boundary of the surface ##x^2 + y^2 \leq 4##. Applying Stokes' to this surface rather than the paraboloid results in a much simpler integral.
Sure, but apparently the problem was to verify both sides of Stokes' theorem by calculating them directly.
Ah, okay, must have missed that.
http://www.upload.ee/image/3322664/20130520_011715.jpg
So please check it out, i think u can understand it better this way :)
I don't see where i did wrong, and i can't really understand what you meant by " The only term that should survive the θ integration is part of the cos2θ expression, and somewhere you lost the - in front of that term." I have - in front ?
Sorry, but replacing one unreadable thing with another even more unreadable thing that takes forever to load isn't an improvement.
argh i haven't learned how to write equations like you do ... And it takes a second for me to open that link , its HD pic of 1 A4 , like 2,3 mb or something. Ill try and write it then somehow.
I don't really need to see it. Did you find where you dropped the minus sign and do you now get the correct answer?
Is this better? No i don't see where...
[itex]\int\int (z^2-x,0,z-3)*(x,y,-1) dxdy=[/itex]
[itex]\int\int (r^4/4*r*cos t-r^2*(cos t)^2-r^2/2+3)r dt dr=[/itex]
[itex]\int\int r^6/4*cos t+r^3*(cos t)^2-r^3/2+3r dt dr=[/itex]
[itex]\int r^6/4*sin t-r^3(1/2(t+cos t*sin t)-r^3/2*t+3r*t dr=[/itex]
[itex]\int 0-r^3*\pi-0-r^3*\pi+6r\pi dr=[/itex]
[itex]\int -2*\pi*r^3+6*r*\pi dr=[/itex]
[itex]-8\pi+12\pi=4\pi[/itex]
\int_0^2\int_0^{2\pi}\frac {r^6}{4}\cos(t) \color{red}{-}r^3\cos^2(t)-\frac{r^3}{2}+3r\,dtdr$$Like I suspected, you dropped a minus sign.
Yeah well that was just a typo, if i had calculated with + there, i would have the answer 12 * pi ,but it was just a typo.
Okay ill write the line integral too. But it says -4 pi is correct.
[itex]r(t)=(2cos t,2 sin t, 2)[/itex]
[itex]dr=(-2sin t,2cos t, 0 )[/itex]
[itex]a=(3y,xz,yz^2)[/itex]
[itex]I=\int (3y,xz,yz^2)(-2sin t,2cos t, 0 )dt=[/itex]
[itex]\int (3y*-2*sin t+x*z*2*cos t)dt=[/itex]
[itex]\int-12(sint)^2+8*(cos t)^2dt=[/itex]
[itex]\int-12*(sint)^2+8-8*(sin t)^2dt=[/itex]
[itex]16*\pi+\int-20(sin t)^2dt=[/itex]
[itex]16*\pi-20*(1/2*t-cost*sint)=[/itex]
[itex]16*\pi-20\pi=-4\pi[/itex]
[itex]I=\int (3y,xz,yz^2)(-2sin t,2cos t, 0 )dt=([/itex]
Sorry for double post , don't know why it happened.
You haven't put the limits in or showed enough that I can follow it, but are you doing$$
\int_{2\pi}^0 -12\sin^2(t) + 8\cos^2(t)\, dt$$
That is the correct direction and that would change the sign if that isn't what you did. That would give ##4\pi## and explain why there doesn't seem to be anything wrong with the other calculation.
FAQ: Flux integral of surface using Stokes theorem
1. What is the concept behind the Flux integral of surface using Stokes theorem?
The Flux integral of surface using Stokes theorem is a mathematical concept that relates the flow of a vector field through a surface to the curl of the vector field on the boundary of the surface. It is based on the fundamental theorem of calculus and is used to calculate the flux of a vector field through a closed surface.
2. How is the Flux integral of surface using Stokes theorem used in real-world applications?
The Flux integral of surface using Stokes theorem has a variety of applications in physics and engineering. It is commonly used in fluid mechanics to calculate the flow of a fluid through a surface, as well as in electromagnetism to determine the electric and magnetic fields around a closed loop. It is also used in computer graphics to simulate the behavior of fluids and electromagnetic fields.
3. What is the equation for the Flux integral of surface using Stokes theorem?
The equation for the Flux integral of surface using Stokes theorem is: ∫∫S (curl F) * dS = ∫C F * dr, where S is the closed surface, C is the boundary of the surface, F is the vector field, and dS and dr are the differential surface and line elements, respectively.
4. How does the Flux integral of surface using Stokes theorem relate to other mathematical concepts?
The Flux integral of surface using Stokes theorem is closely related to other mathematical concepts such as the fundamental theorem of calculus, the divergence theorem, and Green's theorem. It is also a special case of a more general theorem known as the generalized Stokes theorem.
5. What are some common mistakes to avoid when using the Flux integral of surface using Stokes theorem?
Some common mistakes to avoid when using the Flux integral of surface using Stokes theorem include using the wrong orientation for the surface or boundary, not considering the sign convention for the surface and line elements, and not understanding the underlying concepts of vector calculus. It is important to carefully define and orient the surface and boundary, and to have a solid understanding of the principles behind the theorem in order to avoid errors in calculations.
