Flux through cylindrical wedge
The discussion focuses on calculating the flux of the vector field F = x i + y j + z k through a cylindrical surface defined by x^2 + y^2 = 1, bounded by the planes z = 0 and x + y + z = 2. Using Gauss' Theorem, the divergence of F is determined to be 3, leading to the conclusion that the flux equals 3 times the enclosed volume. The volume is calculated using cylindrical coordinates, resulting in a value of 2π, which gives a flux of 6π. However, the participant notes that the multiple-choice answers provided in a test included options that do not match their calculated result. The discrepancy raises questions about the accuracy of their calculations or the test options.
TopCat
Given \textbf{F} = x\textbf{i} + y\textbf{j} + z\textbf{k}, what is the flux of \textbf{F} through the cylinder x^2 + y^2 =1 bounded by the planes z=0, x+y+z=2.
By Gauss' Theorem, \int\int_{S}\textbf{F}\cdot d\textbf{S} = \int\int\int_{V}(\nabla\cdot \textbf{F})dV
But \nabla\cdot \textbf{F}=3, so the flux through the surface equals 3 times the enclosed volume. Using cylindric coordinates to calculate the volume from the integrals or using the fact the the volume is half that of a cylinder of radius 4, the volume is 2\pi and that gives 6\pi as the flux.
However, on a multiple choice test I just took, the answers offered were 0, \pi, 2\pi, 4\pi, and 10\pi. Where did I make a mistake?
Hello!
I did the volume integral with the boundaries:
<br /> \int\int\int_{V}(\nabla\cdot \textbf{F})dV<br />
z = [0, 2 - x - y]
r = [0, 1]
theta = [-pi, pi]
x = r cos(theta)
y = r sin(theta)
and I also got the answer of 6pi :)
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 0 ·
