Flux with a non-uniform electric field
In summary, the electric flux through a surface of vector area S is given by Φ=E→⋅∫ds→=E→⋅S→=EScosθ.
FS98
105
If the electric field is uniform, the electric flux passing through a surface of vector area S is
64345de0db0e5e26f345d9715ee3723b20cb442c
where E is the electric field (having units of V/m), E is its magnitude, S is the area of the surface, and θ is the angle between the electric field lines and the normal (perpendicular) to S.
This is from Wikipedia. Why does it say that the equation above applies if the electric field is uniform. Many of the examples I’ve seen apply the same equation with non-uniform electric fields. For example, a sphere with a charged particle q in the center has an electric field E = kq/r^2 multiply this by the surface area of a sphere 4pi(r^2) to get 4kq(pi) or q/Eo. I assume the electric fields dependence on r^2 means that it’s not uniform.
Because in case of a non-uniform electric field, the flux is given by Φ=∫E⋅ds and this is a surface integral.
When the field is uniform, E can be treated as a constant and the above equation becomes
Φ=E⋅∫ds=E⋅S=EScosθ.
The field is non-uniform in the radial direction. But at any radius r, the field on the surface is uniform (normal to the surface, hence parallel to the area vector).
Likes FS98
Φ=E⋅∫ds=E⋅S=EScosθ.
So the electric field doesn’t need to be constant for this equation to work? There just needs to be a constant value of theta to plug into the equation phi = EScos(theta)?
Related to Flux with a non-uniform electric field
1. What is flux with a non-uniform electric field?
Flux with a non-uniform electric field refers to the measurement of electric field lines passing through a surface that is not evenly distributed. This means that the electric field strength varies across the surface, resulting in a non-uniform distribution of electric flux.
2. How is flux with a non-uniform electric field calculated?
The calculation for flux with a non-uniform electric field involves using the electric field strength at each point on the surface and multiplying it by the area vector at that point. The sum of these values gives the total flux passing through the surface.
3. What is the significance of flux with a non-uniform electric field?
Flux with a non-uniform electric field is important in understanding the behavior of electric fields in real-world situations. It can help explain the distribution of charges and the strength of electric fields in different regions of a surface or object.
4. How does a non-uniform electric field affect flux?
A non-uniform electric field affects flux by causing the electric field lines to be closer together in areas of higher field strength and further apart in areas of lower field strength. This results in a non-uniform distribution of flux passing through the surface.
5. Can flux with a non-uniform electric field be negative?
Yes, flux with a non-uniform electric field can be negative. This occurs when the electric field lines passing through a surface are in the opposite direction of the surface's normal vector. In this case, the flux is considered to be entering the surface rather than leaving it, resulting in a negative value.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
