Focal length of the optical system
In summary: So, in summary, when an object is kept at focus of a convex lens, then an image is formed at infinity. When we pour some drops of water on a plain mirror and move the object around on the principal axis of the lens, the focal length of the lens system is obtained from the equation 1/f = 1/f_1 + 1/f_2 + 1/f_3.
Raghav Gupta
1,011
76
I understand this that when an object is kept at focus of convex lens, then image is formed at infinity.
So when we keep a convex lens above plain mirror and move object needle on the principal axis of convex lens and see a coinciding image with needle on lens and measure distance from lens then it is focal length of convex lens. As the Rays have retraced their path by being normal to plain mirror.
Now, when we pour some drops of water on plain mirror and again keep on top The convex lens, how in this case when the object and image coincides, on measuring the distance from convex lens this is the focal length of the system?
For some images see the link
http://www.seminarsonly.com/Enginee...ctive-Indices-of-Water-And-Turpentine-Oil.php
Science news on Phys.org
when you have water in between the convex lens and a plane mirror, the water will act like a concave lens.
now, for a system of lenses, for example, if you place 3 convex lenses in contact, with each lens having focal lengthe ##f_1,f_2,f_3##, then we difine the total power P of the configuration as $$P=P_1+P_2+P_3$$
hence the focal length of a single lens which can act like the given combination is obtained from :
$$1/f = 1/f_1 + 1/f_2 + 1/f_3$$
now try to use this relation.
This is a experiment. I guess you might have done it for physics practical?
I will give you a link so you may remember it
http://uotechnology.edu.iq/dep-laserandoptoelec-eng/English/laboratory/1/U p/Determination the refractive index of a liquid by a liquid l.pdf
I know that relation and all formulas, but
in 1/F=1/f1+1/f2 from where we will get F and f2? 2 variables here to solve. One would say that F we will get by seeing the image and object coincide again but how that distance measured is theoretically focal length of the convex and liquid lens system?
f1 we have determined by measuring the distance of the image and object needle being coincident.
Thanks Aditya for giving me an explanation but got the answer of my query from blue leaf, if you see my Focus point thread in general physics.
I think sometimes way of expressing questions have a lot of impact on people (As I think I did there and kudos to the guy for explaining in a nice way).
Related to Focal length of the optical system
1. What is the focal length of an optical system?
The focal length of an optical system is the distance between the center of the lens or mirror and the point where light rays converge to form a sharp image. It is typically measured in millimeters (mm) or centimeters (cm).
2. How is the focal length of an optical system determined?
The focal length of an optical system is determined by the curvature of the lens or mirror and the relative distance between the lens or mirror and the object being viewed. It can also be calculated using the formula f = R/2, where f is the focal length and R is the radius of curvature of the lens or mirror.
3. What is the relationship between focal length and magnification?
The focal length of an optical system is directly proportional to its magnification. This means that a shorter focal length will result in a larger magnification, while a longer focal length will result in a smaller magnification.
4. How does the focal length affect the field of view in an optical system?
The focal length of an optical system also affects its field of view. A shorter focal length will result in a wider field of view, allowing you to see more of the surrounding area. A longer focal length will result in a narrower field of view, allowing you to focus in on a specific area or object.
5. Can the focal length of an optical system be changed?
Yes, the focal length of an optical system can be changed by using lenses or mirrors with different curvatures, or by adjusting the distance between the lens or mirror and the object being viewed. This is how cameras and telescopes are able to zoom in and out to change their focal length and magnification.
