- #36
- 23,377
- 5,733
Thanks, this is what I have, BUT the calculations for processes C and D would change depending on your clarification for the question I had asked earlier.Chestermiller said:
l don't quite understand. Are you saying that my results for C and D in post #36 are incorrect, or are you saying that you results for C and D in this post need updating?guhag said:Thanks, this is what I have, BUT the calculations for processes C and D would change depending on your clarification for the question I had asked earlier.
Chet, I meant I would have to correct *my* work once my doubt in post 34 is clarified and that affects processes C and D. Thanks.Chestermiller said:l don't quite understand. Are you saying that my results for C and D in post #36 are incorrect, or are you saying that you results for C and D in this post need updating?
The results in these figures for part (b) show that the reversible work between the initial and final states of our system in this focal problem depends on the reversible path we select. So far we've seen that, for all the reversible paths we've looked at, the reversible work exceeds that actual irreversible work. Do you think that this holds in general, or is it possible that there are reversible paths that give less work than the irreversible path? If so, can you propose any?
At the end of step 1, the pressure is not P1. This is because there is a pressure- and temperature change during step 2. The volume ratio for step 1 is the same as the volume ratio for the whole process, since volume does not change in step 2.guhag said:PROCESS C
1. Isothermal expansion at temperature To from Vo to V1
2. Isochoric cooling at volume V1 from To to T1
I got this for W(total)= RT0ln(V1/V0). For the overall process, V1/V0 = (Po/P1) * (T1/T0). For the 1st step,V1/V0 = (Po/P1) . Since work for step 2 =0, W(total) = W1, hence I used V1/V0 = Po/P1 from the 1st step. Why is that not correct?
Similar case with process D.
I got it, thanks ! Here is the corrected graph for all the processes, finally it seems to match with yours !Chestermiller said:At the end of step 1, the pressure is not P1. This is because there is a pressure- and temperature change during step 2. The volume ratio for step 1 is the same as the volume ratio for the whole process, since volume does not change in step 2.
Excellent. Next, please consider the questions I posed in post 39.guhag said:I got it, thanks ! Here is the corrected graph for all the processes, finally it seems to match with yours !
I can't prove that this holds in general but I think that reversible paths produce more work than irreversible as in the reversible case, the entire area under the path connecting initial and final states is used. I need to think more about it, though !Chestermiller said:The results in these figures for part (b) show that the reversible work between the initial and final states of our system in this focal problem depends on the reversible path we select. So far we've seen that, for all the reversible paths we've looked at, the reversible work exceeds that actual irreversible work. Do you think that this holds in general, or is it possible that there are reversible paths that give less work than the irreversible path? If so, can you propose any?
Consider this 3-step path E:guhag said:I can't prove that this holds in general but I think that reversible paths produce more work than irreversible as in the reversible case, the entire area under the path connecting initial and final states is used. I need to think more about it, though !
Dimensionless work, W/nRT0 = 0.25* ln(V1/V0) = W( for path C) /4. This is less than W(irrev).Chestermiller said:Consider this 3-step path E:
1. Isochoric cooling from To to To/4
2. Constant temperature expansion at To/4 from Vo to V1
3. Isochoric heating from To/4 to T1
My motivaation was this: Case D was lower than C, because case C was at To and case D was at T1<To. So I could get the work as low as I wanted by expanding from Vo to V1 at lower temperature, while doing whatever temperature changes at constant volume.guhag said:Dimensionless work, W/nRT0 = 0.25* ln(V1/V0) = W( for path C) /4. This is less than W(irrev).
How did you came up with this example, I wonder? I don't mean to disrupt your flow of thought (so you can check the question below, when you see fit):
$$V_1=V_0\frac{P_0T_1}{P_1T_0}$$So,$$P_b=\frac{P_0V_0}{4}\frac{P_1T_0}{V_0P_0T_1}=\frac{T_0}{T_1}\frac{P_1}{4}$$guhag said:Another question: I tried to chart this process out on a P-V diagram to see if I could deduce this graphically, for instance BUT was not successful.
As an exercise within an exercise ad infinitum :), the state variables for each of these steps I calculated are (to plot them in the P-V diagram):
1. (P0,T0,V0) to (Pa, T0/4, Vo) where Pa = P0/4
2. (Pa, T0/4, Vo) to (Pb,T0/4, V1) where Pb* V1 = Pa * V0 = nRT0/4
$$P_b=\frac{T_0}{T_1}\frac{P_1}{4}$$guhag said:3. (Pb,T0/4, V1) to (P1,T1, V1) where Pb = (P1/T1) * (1/4)
What part are you trying to prove geometrically?guhag said:a. Are these states of the system correct or did I mess them up?
b. If they are correct, I wonder (with appropriate reservations on my rusty math skills) why am I not able to prove this geometrically?
Thanks. Typo in my calculation:Chestermiller said:$$V_1=V_0\frac{P_0T_1}{P_1T_0}$$So,$$P_b=\frac{P_0V_0}{4}\frac{P_1T_0}{V_0P_0T_1}=\frac{T_0}{T_1}\frac{P_1}{4}$$$$P_b=\frac{T_0}{T_1}\frac{P_1}{4}$$
I was trying to plot the process E on the P-V diagram and calculate the area to see how it compared with other reversible processes (A-D). I will try this on my own and ask you if I don't make any headway.Chestermiller said:What part are you trying to prove geometrically?
I am afraid I don't follow your insight here...Chestermiller said:My motivaation was this: Case D was lower than C, because case C was at To and case D was at T1<To. So I could get the work as low as I wanted by expanding from Vo to V1 at lower temperature, while doing whatever temperature changes at constant volume.
OKguhag said:I was trying to plot the process E on the P-V diagram and calculate the area to see how it compared with other reversible processes (A-D). I will try this on my own and ask you if I don't make any headway.
On a side note: I am trying to read a J.Chem.Edu article (attached) on 1st law. I hope you don't mind if I come back to you with questions on it.
What I learned by comparing reversible processes C and D is that, if all the heat transfer is carried out at constant volume (no work in such steps) and all the work is carried out at constant temperature, then I can make the amount of work done in the overall process as low as I desire by carrying out the expansion at as low a temperature as I choose. In process E, all the heat transfer is carried out in steps 1 and 3 at constant volume, and I chose a low enough temperature for step 2 (To/4) so that the overall reversible work is very low (even lower than for the irreversible process between the same two end states).guhag said:I am afraid I don't follow your insight here...
Secondly, this is not obvious to me. why you compare two reversible processes C and D instead of compare processes E, C (or D) and irreversible...
This is a BEAUTIFUL explanation. Wow ! Thank you, Chet. I've learned a LOT already from you in this thread and there is still more to go :)Chestermiller said:What I learned by comparing reversible processes C and D is that, if all the heat transfer is carried out at constant volume (no work in such steps) and all the work is carried out at constant temperature, then I can make the amount of work done in the overall process as low as I desire by carrying out the expansion at as low a temperature as I choose. In process E, all the heat transfer is carried out in steps 1 and 3 at constant volume, and I chose a low enough temperature for step 2 (To/4) so that the overall reversible work is very low (even lower than for the irreversible process between the same two end states).
I do't know what you mean.guhag said:This is a BEAUTIFUL explanation. Wow ! Thank you, Chet. I've learned a LOT already from you in this thread and there is still more to go :)
Is there a mathematical generalization behind this ? Or, it depends upon a particular situation, like this case?
Is nobody willing to attempt part (c), the entropy change for each of the 5 reversible paths that we have identified?guhag said:
I haven't checked this thread in a while. Company layoffs looming ahead. I'll try part c) this week, for sure.Chestermiller said:Is nobody willing to attempt part (c), the entropy change for each of the 5 reversible paths that we have identified?
Have you read over the posts in this thread. If you had, you would know that there are an infinite number of reversible paths between the initial and final states of the irreversible adiabatic process analyzed here and that the work along some of these reversible paths is greater than for the irreversible path while, along others, the work is less than for the irreversible path; however the entropy change is the same for all the reversible paths as for the irreversible path.Lollo said:@ChetMiller I have not found any explicit treatment, in books, about irreversible adiabatic transformations. 1.1) Very often it is said that, in an adiabatic expansion, given the same initial conditions and final pressure (or final volume) the work done by an irreversible one is less than that done by a reversible one, but I have not yet found an explicit demonstration of this.
1.2) Also, it is said that in an adiabatic compression, the work done by an irreversible is greater than that done by a reversible, given the same initial conditions and final pressure (or final volume).
In short, it should hold $$|W_irr < W_rev|$$. How to prove it?
3) Moreover, it was not understood what inequalities should exist between pressure, volume and temperature between irreversibles and reversibles. Given the same initial conditions and final pressure, is the final temperature in an irreversible adiabatic transformation greater or less than the final temperature in a reversible adiabatic transformation? If yes, why?
There exists no reversible adiabatic process between the same two end states as for an irreversible adiabatic process. We know this because the entropy change for an adiabatic irreversible process is positive and the entropy change for an adiabatic reversible process is zero. So if we have an adiabatic irreversible process, all reversible processes between the same two end states must be non-adiabatic.Lollo said:@Chestermiller I am very surprised that there are cases where, in reversible adiabatic processes, the work is less than in the corresponding irreversible path.
As I showed in the examples in the present thread, this is not correct.Lollo said:I always thought that the work carried out on the system in irreversible adiabatic compression is greater than the work carried out on the system in reversible adiabatic compression, and that the work carried out on the system in irreversible adiabatic expansion is always less than the work carried out on the system in reversible adiabatic compression. Is this not so? I have seen several answers on StackExchange saying this, and they have never been refuted. See for example https://chemistry.stackexchange.com...rreversible-adiabatic-compression-greater-tha.
If the two end states are the same for all the paths and, if entropy is a state function, what other possibility is there?Lollo said:"the entropy change is the same for all the reversible paths as for the irreversible path." How to prove that? It seems to me that point (c) has been left open. Can you post a solution for the benefit of the forum?
