Focused proton beam waist diameter
In summary, the LHC achieves a beam waist diameter of approximately 64 microns, limited by the emittance and spread in flight direction at the smallest point. Electromagnetic accelerators can reduce their emittance, but this is not practical at the LHC. Strong focusing magnets near the interaction point also have limits. Electron cooling is a potential solution, but there may be significant losses due to recombination of electrons. However, with antiprotons, this is not a concern.
The minimal waist diameter is roughly determined by emittance (size of the bunches in phase space) and the spread in flight direction at the smallest point.
The emittance is given by the proton source - how uniform the protons are in position and velocity. After that the emittance can only grow, at best you keep it nearly the same the whole time.
Electron-positron accelerators can reduce their emittance via synchrotron radiation, some proton accelerators can use electron cooling or stochastic cooling, but these would be impractical at the LHC.
A larger spread in flight direction can lead to a smaller spread in position, but the beams still have to fit into the beam pipe - to get a large spread inside the experiments but not in the rest of the accelerator you need strong focusing magnets very close to the interaction point and there are simply limits how much you can do there.
Likes BrandonBerchtold
Electron cooling seems useful but won't there be significant losses due to the recombination of electrons, or is there a way of increasing the probability of electron scattering such that recombination losses become negligible?
You lose some protons that form hydrogen atoms but there are conditions where that rate is small.
With antiprotons you don't have that mechanism, of course.
Related to Focused proton beam waist diameter
1. What is a focused proton beam waist diameter?
A focused proton beam waist diameter refers to the smallest diameter of a proton beam that has been focused using a series of magnetic lenses. It is an important parameter in proton beam therapy, as it determines the precision and accuracy of the treatment.
2. How is the focused proton beam waist diameter determined?
The focused proton beam waist diameter is determined by the properties of the proton beam, such as its energy and intensity, as well as the strength and configuration of the magnetic lenses used to focus the beam. Computer simulations and experimental measurements are often used to determine the optimal waist diameter for a specific treatment.
3. Why is the focused proton beam waist diameter important in proton therapy?
The focused proton beam waist diameter is important because it determines the size of the area that will be irradiated by the proton beam. A smaller waist diameter means a more precise and localized treatment, while a larger waist diameter may result in unintended radiation to healthy tissues surrounding the target area.
4. How does the focused proton beam waist diameter affect the effectiveness of proton therapy?
The focused proton beam waist diameter plays a crucial role in the effectiveness of proton therapy. A smaller waist diameter allows for a higher dose of radiation to be delivered to the tumor, while minimizing the dose to surrounding healthy tissues. This can result in a more effective treatment with fewer side effects.
5. What factors can affect the focused proton beam waist diameter?
The focused proton beam waist diameter can be affected by various factors, including the energy and intensity of the proton beam, the strength and alignment of the magnetic lenses, and the properties of the tissues being treated. Other external factors such as temperature and humidity can also impact the waist diameter. It is important for these factors to be carefully controlled to ensure an accurate and precise treatment.
  • Classical Physics
14K
16K
12K
