For a set S, there is always a sequence converging to sup(S)
In summary: Awesome. Two questions: First, how can I justify that we can let ##a_n## be the element in ##(\sup(S) - \frac{1}{n},~ \sup(S))## that must exist? I feel like such a construction is very non-constructive, so I don't see why it's valid. Second, why in particular did the the value ##\frac{1}{n}## work? Is the only criteria that it converges to zero? Could I have just as easily replaced ##\frac{1}{n}## with ##\frac{1}{n^2}##?
Mr Davis 97
1,462
44
[/B]
Let ##S\subset \mathbb{R}## be nonempty and bounded above. Show that there must exist a sequence ##\{a_n\}_{n=1}^\infty\subseteq S## such that ##\lim_{n\to\infty}a_n=\sup(S)##.
Here is my idea. Let ##\epsilon >0##. Then there must exist an ##a \in S## such that ##\sup(S) - a< \epsilon##, by nature of ##\sup(S)## being the least upper bound.
So clearly we can always find an element ##a## that is arbitrarily close to ##\sup(S)##. My problem is that I don't know how to make this formal. How would I construct the sequence necessary?
What about this: for each ##n \in \mathbb{N}## there must must exist an ##a \in (\sup(S) - 1/n,~ \sup(S))##. And so we construct the sequence out of the ##a##'s that must exist, so that ##a_1 \in (\sup(S) - 1,~ \sup(S))##, ##a_2 \in (\sup(S) - 1/2,~ \sup(S))##, and so on.
That's the idea. So you have ##a_n \in ( \sup S - \frac 1 n,\sup S)##. Now just finish:
To show ##a_n \to \sup S##, suppose ##\epsilon >0##. Then if ##n > ~...##
Likes Mr Davis 97
Mr Davis 97 said:
[/B]
Well... Suppose that we construct the sequence ##(a_n)## by letting ##a_n## be the element in ##(\sup(S) - \frac{1}{n}, \sup(S))## that is guaranteed to exist by nature of the supremum. Then ##\forall n \in \mathbb{N}##, ##\sup(S) - a_n < \frac{1}{n}##.
Now, let ##\epsilon > 0##. Then by the Archimedean principle there exists an ##N \in \mathbb{N}## such that ##\frac{1}{N} < \epsilon##. If ##n \ge N##, then ##|a_n - \sup(S)| = |\sup(S) - a_n| = \sup(S) - a_n < \frac{1}{n} \le \frac{1}{N} < \epsilon##. This proves that ##\lim a_n = \sup(S)##.
Is this a correct argument?
Why not just say that if there is no sequence convering to sup(S) then there is an epsilon nbd about sup(S) which contains no members of S, and this contradicts the fact that sup(S) is the least upper bound.
When I was doing this problem, I learned that if ##sup(S)## isn't an accumulation point of the sequence, then it is contained in the sequence.
If sup(S) belongs to S then the proof is trivial, so assume sup(S) doesn't belong to S.
Totally correct. You could have also used squeeze theorem to conclude.
Not "the" element, "any" such element. You can pick one and call it ##a_n##.
Yes.
Likes Mr Davis 97
LCKurtz said:
Not "the" element, "any" such element. You can pick one and call it ##a_n##.Yes.
Why are we allowed to pick one and call it ##a_n##?
Also, I feel like we could also show that there is always a nondecreasing sequence that converges to ##\sup(S)##. I can visualize the process of assigning values in the same way as above, but instead of using ##\frac{1}{n}## we assign each element ##a_n## to be in the interval ##(\sup(S) - a_{n-1}, \sup(S))## so that ##a_n \ge a_{n-1}## and ##a_n## converges to ##\sup(S)##. Would this work?
(1) This is a very good question. Consider this lemma.
Let ##A \subseteq\mathbb{R}## be a non empty set with a LUB ##c:= \sup A##.
For every ##r >0##, there is ##a \in A## with ##c \leq a + r##.
Proof: If not, there is r>0 s.t. for all ##a \in A## we would have ##c > a + r## or equivalently ##c-r>a##, contradicting the definition of ##c##.
Now, you can apply this lemma for ##r = 1/n## and ##a = a_n##.
(2) Yes, any sequence ##(b_n)## converging to 0 works, because we have:
$$0\leq |\sup A - a_n| \leq b_n$$
By the squeeze theorem:
$$\lim_n |\sup A -a_n| = 0$$
Which clearly is equivalent with
$$\lim_n a_n = \sup A$$
Likes Mr Davis 97
You know there is an element in the interval so there may be many, but at least one. So pick one. There's no law against naming it, so call it something sensible like ##a_n##.
Yes, it could work, but you need to be careful. Just requiring ##a_{n+1} > a_n## might not be enough after you pick ##a_1##. Do you see how you need to be careful if the set S has a cluster point ##p < sup(S)##?
Likes Mr Davis 97
We haven't defined cluster points yet, but I think I might see what you mean. Defined this way maybe ##a_n## will converge to some ##p < \sup(S)##. I'm not seeing how to get ##a_n## to both converge and be nondecreasing using my idea...
Think about choosing ##a_{n+1} \ge \max\{a_n,\sup S - \frac 1 n\}##
Likes Mr Davis 97
So do we have essentially exactly what we had before, except we have ##a_{n+1} \in ( \operatorname{max} \{ a_{n}, \sup(S) - \frac{1}{n} \} , \sup(S))## instead of just ##a_n \in (\sup(S) - \frac{1}{n}, \sup(S))##? For the latter part we have an inductive definition. What would the initial case be?
Related to For a set S, there is always a sequence converging to sup(S)
1. What is the definition of a sequence converging to sup(S)?
A sequence converging to sup(S) is a sequence of numbers that approaches the supremum, or the least upper bound, of a given set S. In other words, as the sequence progresses, the numbers get closer and closer to the highest value that is still less than or equal to all the elements in S.
2. How is the supremum of a set S determined?
The supremum of a set S is the smallest number that is greater than or equal to all the elements in S. It can be found by taking the set of upper bounds of S and finding the smallest element in that set.
3. Is the sequence converging to sup(S) unique?
No, the sequence converging to sup(S) is not necessarily unique. There can be multiple sequences that converge to the same supremum. However, all these sequences will have the same limit, which is the supremum of S.
4. Does every set S have a supremum?
No, not every set S has a supremum. A set must be bounded above in order to have a supremum. This means that there must be a finite or infinite upper bound for all the elements in S.
5. How does the concept of convergence to sup(S) relate to real analysis?
The concept of convergence to sup(S) is an important concept in real analysis. It is used to prove the existence of limits and to show the convergence of sequences and series. It also helps to define the continuity of functions and to study the behavior of functions near the supremum of a set.
