I For fun: How fast would an open-front CRT kill an average human? [A?]
  • I
  • Thread starter Thread starter DynV
Cutting out the front of a CRT would not kill an average adult human due to the low beam current of less than 100 microamperes. The CRT requires a vacuum to function, and there is not enough vacuum volume to alter the room's air pressure significantly. Blood would not boil unless the room was evacuated to a vacuum, which is not the case in this scenario. The discussion concluded with a humorous note, emphasizing the lighthearted nature of the topic. Overall, the CRT's design prevents it from being lethal in the described conditions.
DynV
The following in only for fun: If one would cut out the front of a CRT, how fast would it kill an average adult human? If the room needs to be filled with a gas, imagine the person wore a diving mask, if the room needed to be filled with acid, imagine there's some kind of protective gel or deep sea suit that would keep the victim alive (until the beam killed him/her), as long as it's not ridiculously expensive (eg 1M$). I suspect this might be an advanced topic, but I was conservative and marked it as intermediate, feel free to change it.
Happy dicking around
  • Skeptical
Likes PeroK
Ask a silly question, get a silly answer.
The CRT would not kill you. The beam current is less than 100 uA, to continue functioning, the CRT would need to maintain a vacuum.
There is insufficient volume of vacuum in a CRT, to change the air pressure in the room.
Your blood would not boil, unless you evacuated the room to a vacuum, because you felt sorry for the electrons in the beam.
  • Haha
Likes berkeman
My blood is boiling now.
Likes berkeman
Good reply by @Baluncore so the thread is done now.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
