MHB For j >1 the first 2^j digits are correct
  • Thread starter Thread starter mathmari
The discussion centers on the iteration formula \(x_{j+1}=2x_j-3x_j^2\) with a starting point of \(x_0=0.3\) to approximate \(\frac{1}{3}\). It is demonstrated that for \(j \geq 1\), the first \(2^j\) digits of \(x_j\) are correct for \(\frac{1}{3}\). Induction is suggested as the method to prove this, with a base case established for \(j=1\) and an inductive hypothesis for \(j=k\). The inductive step confirms the formula holds for \(j=k+1\), leading to the conclusion that the approximation improves exponentially with each iteration. The discussion concludes with the correction of an initial calculation error, affirming the validity of the results.
mathmari
MHB
Hey! 😊
We have the iteration formula $$x_{j+1}=2x_j-3x_j^2$$ and using the starting point $x_0=0.3$ we get the following approximations for $\frac{1}{3}$ :
\begin{align*}&x_1=2x_0-3x_0^2=2\cdot 0.3-3\cdot 0.3^2=0.33 \\ &x_2=2x_1-3x_1^2=2\cdot 0.33-3\cdot 0.33^2=0.3333 \\ &x_3=2x_2-3x_2^2=2\cdot 0.3333-3\cdot 0.3333^2=0.33333333\end{align*}
Now I want to show that for $j\geq 1$ the first $2^j$ digits of $x_j$ are correct for $\frac{1}{3}$.
It is $\frac{1}{3}=0.33333333333333333333333333\ldots$.
The approximation $x_1$ has the first $2=2^1$ digits correct.
The approximation $x_2$ has the first $4=2^2$ digits correct.
The approximation $x_3$ has the first $8=2^3$ digits correct.To show that it holds for $j\geq 1$ do we have to use induction? :unsure:
Mathematics news on Phys.org
Hi mathmari!
Induction seems to be the way to go yes.
So we need to write $x_j$ in terms of $2^j$. Can we find such an expression? šŸ¤”
As a power of $10$ we get \begin{align*}x_j&=\sum_{i=1}^{2^j}\frac{3}{10^i}=3\cdot \sum_{i=1}^{2^j}\frac{1}{10^i}=3\cdot \left (\sum_{i=0}^{2^j}\frac{1}{10^i}-1\right )=3\cdot \frac{\frac{1}{10^{2^j+1}}-1}{\frac{1}{10}-1}-3=3\cdot \frac{\frac{1}{10^{2^j+1}}-1}{-\frac{9}{10}}-3=-\frac{10}{9}\cdot 3\cdot \left (\frac{1}{10^{2^j+1}}-1\right )-3=-\frac{10}{3}\cdot \left (\frac{1}{10^{2^j+1}}-1\right )-3=-\frac{10}{3}\cdot \frac{1}{10^{2^j+1}}+\frac{10}{3}-3\\ & =-\frac{1}{3}\cdot \frac{1}{10^{2^j}}+\frac{1}{3}\end{align*} right?
So by induction on $j$ we get:
Base Case: For $j=1$ we get the desired result, as seen.
Inductive Hypothesis: We suppose that the formula is true for $j=k$, i.e. $\displaystyle{x_k=-\frac{1}{3}\cdot \frac{1}{10^{2^k}}+\frac{1}{3}}$.
Inductive Step: We want to show that the formula is true also for $j=k+1$ : \begin{align*}x_{k+1}=2x_k-3x_k^2\ &\overset{(IH)}{=} \ 2\left (-\frac{1}{3}\cdot \frac{1}{10^{2^k}}+\frac{1}{3}\right )-3\left (-\frac{1}{3}\cdot \frac{1}{10^{2^k}}+\frac{1}{3}\right )^2\\ & =-\frac{2}{3}\cdot \frac{1}{10^{2^k}}+2\cdot \frac{1}{3}-3\left (\frac{1}{3^2}\cdot \frac{1}{10^{2^{k+1}}}-2\cdot \frac{1}{3}\cdot \frac{1}{10^{2^k}}\cdot \frac{1}{3}+\frac{1}{3^2}\right ) \\ & =-\frac{2}{3}\cdot \frac{1}{10^{2^k}}+2\cdot \frac{1}{3}-\frac{1}{3}\cdot \frac{1}{10^{2^{k+1}}}+2\cdot \frac{1}{10^{2^k}}\cdot \frac{1}{3}-\frac{1}{3}\\ & =\frac{1}{3}-\frac{1}{3}\cdot \frac{1}{10^{2^{k+1}}} \end{align*}
So we get that this hold for every $j\geq 1$ (Happy)
mathmari said:
As a power of $10$ we get \begin{align*}x_j&=-\frac{1}{3}\cdot \frac{1}{10^{2^j}}+\frac{10}{3}\end{align*} right?
Suppose we substitute $j=1$. Then we should get $x_1=0.33$ yes?
$$x_1=-\frac{1}{3}\cdot \frac{1}{10^{2^1}}+\frac{10}{3}=-\frac{1}{300}+\frac{10}{3}=3.33$$
That's not correct is it? :eek:
I found my error! I edited my previous post and the correct result came out!
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a ā€œconvenient notationā€ he referred to as a ā€œdelta functionā€ which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
