For Statics:Simple Systems of Equations to Solve Equilibrium Problems
In summary, the student attempted to solve a static equilibrium problem, but did not have a systematic easy approach. The student was provided with a model answer, which explained how to solve the problem using one of the equations.
jklops686
40
I have a picture attached with this static equilibrium problem.
(Solve system for Fac and Fab)
Sum of x and y both=0
I just don't have a systematic easy approach to solving these systems. Does anyone have one? From the picture, they used the system of equations and add them together cancelling variables, but I don't know how exactly they did that. This class would be so much easier if I could do this well!
Nobody does. That is because this sort of problem can be arbitrarily complicated.
Instead you have to use your understanding of physics and resolve all the forces into appropriate components.
The heart of the matter is that the sum of all the vectors has to be zero.
Sometimes there is a shortcut using your knowledge of geometry - for instance, three forces have to form a triangle (if they are to sum to zero) and you know about the geometry of a triangle. This one can be solved using the sine rule for arbitrary triangles. However, the general approach to these problems has been demonstrated in the model answer.
Of course it helps to have some idea of which way the forces actually point - in fig2, for eg, the only way those forces cancel is if one of them points the opposite way... and sure enough...
That does make sense, thanks for the reply. I understand how to set most of the problems up and I'm great with visualization and geometry it's just once they are set up, then I am having troubles solving for the unknowns. My algebra is gone out the window or something. From the picture, they used the system of equations and add them together cancelling variables, but I don't know how exactly they did that.
You don't always have to use the setup that is provided for you.
Do you understand how the simultanious equations were obtained?
I'm not sure what other way i'd use. It seems easy but I just can't remember how it's solved. And Yes I understand that the equations were obtained by adding up the x force components and then the same for the y components and setting them equal to zero.
There is a very standard way to solve such problems. It is not always the fastest way, but it is one that works every time. You just use one of the equations to solve for one variable in terms of the other; then you put that expression into the other equation.
In your case you have two equations of the form a*x + b*y = 0, c*x + d*y = e. The unknowns are x and y, and the given parameters are a, b, c, d, e. You can solve for x in terms of y from the first equation: a*x + b*y = 0 ==> x = -(b/a)*y (since a ≠ 0). Now, where you see x in the second equation, just substitute in that expression, so the second equation now becomes c*(-b/a)*y + d*y = e, or [d - (b*c/a)]*y = e. If d - (b*c/a) ≠ 0 we can solve for y by division: y = e/[d - (b*c/a)]. Once we know y, we can substitute that into our x-expression to find x.
Note that if d - (b*c/a) = 0 we will have an equation of the form 0*y = e. If e ≠ 0 this is an impossible equation, which indicates that we must have made an error in setting up the problem (or else were handed an inconsistent system by somebody evil). On the other hand, if e = 0 we have the equation 0*y = 0, which allows any value whatsoever for y.
Later, if and when you take linear algebra you will learn such methods as "row reduction", etc., but they are really nothing more than the above method made more streamlined.
So it is solving the simultanious equations that gives you trouble?
Ray has described the brute-force approach.
There are also a bunch of tricks to use for shortcuts ... with practise you get used to it.
Related to For Statics:Simple Systems of Equations to Solve Equilibrium Problems
1. What is the purpose of studying simple systems of equations in statics?
In statics, simple systems of equations are used to solve equilibrium problems. This is important because it allows us to determine the forces and moments acting on a static object. By understanding the equilibrium of forces, we can design structures that are stable and safe.
2. What are some common examples of simple systems of equations in statics?
Some common examples of simple systems of equations in statics include finding the forces acting on a bridge, calculating the weight distribution of a building, and determining the tension in cables supporting a suspension bridge. These equations are also used in everyday objects such as furniture, machines, and vehicles.
3. How do you solve equilibrium problems using simple systems of equations?
To solve equilibrium problems using simple systems of equations, we first identify all the forces and moments acting on an object. Then, we set up equations for each direction (x, y, z) and for each moment. We can then solve the equations simultaneously to find the unknown forces and moments.
4. What are some common mistakes when using simple systems of equations to solve equilibrium problems?
One common mistake is not considering all the forces and moments acting on an object. It is important to carefully analyze the problem and identify all the relevant forces and moments. Another mistake is not using the correct sign convention for forces and moments, which can lead to incorrect solutions.
5. How can I improve my understanding of simple systems of equations in statics?
To improve your understanding of simple systems of equations in statics, it is important to practice solving various types of problems. You can also seek help from a tutor or join a study group to discuss and solve problems together. Additionally, reviewing the basic principles and concepts of statics can also help strengthen your understanding of simple systems of equations.
  • General Math
  • Differential Equations
