For which parameter values the function is continuous and differentiable
In summary, the function is continuous and differentiable at x=2 for all values of a and b as long as c is chosen such that b=2-c and a=c+1/4. There are infinitely many solutions for a and b, but they all fall into this class of solutions.
Yankel
395
For which values of a,b and c, the next function is continuous and differentiable at x=2 ?
[tex]\left\{\begin{matrix} 3x-1 & x\leq 2\\ ax^{2}+bx+c & x>2 \end{matrix}\right.[/tex]
1. b=2-c
2. b=6+2c+2a
3. 7+c-2a
4. b=3-a-(3/4)c
I know that f(2)=5, and so is the limit of f when x goes to 2 from the left side.
I have calculated the limit when f goes to 2 from the right side, and I got:
4a+2b+c
and so for continuously I need:
4a+2b+c = 5
but here I got stuck...
The only point you need to look at is $x = 2$, as all the others must be continuous and differentiable (remember all polynomials are well-behaved).
Recall that for a function to be continuous at $a$, you need:
$$\lim_{x \to a^{-}} f(x) = \lim_{x \to a^{+}} f(x)$$
So in your case, you need to show that the following is true:
$$\lim_{x \to 2^{-}} 3x - 1 = \lim_{x \to 2^{+}} ax^2 + bx + c ~ ~ ~ \Longleftrightarrow ~ ~ ~ 5 = 4a + 2b + c$$
Which is what you got, so this is correct. But, you also need differentiability.
Recall that for a function $f(x)$ to be differentiable at $a$, you need:
$$\lim_{x \to a^{-}} f'(x) = \lim_{x \to a^{+}} f'(x)$$
So, differentiate both pieces of the function, and show that the following is true:
$$\lim_{x \to 2^{-}} 3 = \lim_{x \to 2^{+}} 2ax + b ~ ~ ~ \Longleftrightarrow ~ ~ ~ 3 = 4a + b$$
You are now left with two equations in three unknowns:
$$4a + 2b + c = 5$$
$$4a + b = 3$$
Subtract the second from the first, to obtain:
$$b + c = 2 ~ ~ ~ \Longleftrightarrow b = 2 - c$$
And substitute this back into the second:
$$4a + 2 - c = 3 ~ ~ ~ \Longleftrightarrow ~ ~ ~ a = \frac{1}{4} \left ( c + 1 \right )$$
This gives you $a$ and $b$ in terms of $c$. Choose any $c$, for instance $c = 2$, and you get:
$$a = \frac{3}{4} ~ ~ ~ \text{and} ~ ~ ~ b = 0$$
That is one solution, out of infinitely many. This is also the only class of solutions.
1. b=2-c
2. b=6+2c+2a
3. 7+c-2a
4. b=3-a-(3/4)c
4a+2b+c
4a+2b+c = 5
You have to impose first that $\displaystyle \lim_{x \rightarrow 2 +} f(x) = \lim_{x \rightarrow 2 -} f(x)$ and after that $\displaystyle \lim_{x \rightarrow 2 +} f ^{\ '} (x) = \lim_{x \rightarrow 2 -} f^{\ '}(x)$... Kind regards
$\chi$ $\sigma$
This is true, but not an obvious statement. It looks like the definition of "continuous" but derivatives are NOT necessarily contuinuous. What is true is that any derivative, even if not continuous, satisfies the "intermediate value theorem".
$$4a + 2b + c = 5$$
$$4a + b = 3$$
FAQ: For which parameter values the function is continuous and differentiable
What does it mean for a function to be continuous?
A function is considered continuous if the graph of the function has no breaks or holes. This means that the output of the function changes smoothly as the input changes.
How can I determine if a function is continuous?
A function is continuous if it satisfies the three conditions of continuity: the function is defined at the point in question, the limit of the function at that point exists, and the limit of the function at that point is equal to the value of the function at that point.
What does it mean for a function to be differentiable?
A function is considered differentiable if it has a well-defined derivative at every point in its domain. In other words, the function has a tangent line at every point on its graph.
How can I determine if a function is differentiable?
A function is differentiable if it has a derivative at every point in its domain. This can be determined by using the definition of the derivative or by checking if the function satisfies the differentiability criteria, such as the existence of a tangent line at every point and the continuity of the tangent line.
Can a function be continuous but not differentiable?
Yes, a function can be continuous but not differentiable. This can occur at points where the function has a sharp turn, corner, or vertical tangent line. In these cases, the function is still continuous, but it does not have a well-defined derivative at those points.
