Force analysis of a spring-bob system
  • Thread starter Thread starter tellmesomething
    Force Spring
The discussion centers on understanding the dynamics of a spring-bob system, particularly how maximum elongation occurs when forces are balanced. The gravitational and electrostatic forces act to accelerate the bob, while the spring force decelerates it. A key point raised is whether the spring force can exceed the downward forces to achieve a velocity of zero, leading to upward motion. Participants emphasize that considering energy rather than just forces is crucial for grasping the concept. The conversation concludes with a clarification that energy dynamics play a significant role in this analysis.
tellmesomething
A small bob of charge +Q and mass 5kg is suspended from a spring of force constant k=10^4N/m and is held at rest 50cm above an isolated point charge -Q fixed on the ground. The spring just stretched initially. When the bob is released, the naximun elongation of the spring is 10cm. Then Q=(25n)uc where n=?
None
I dont need anyone to do the sum directly please. I just need some hints, please dont give me the solution.
Im unable to understand how the bob will hit a maximum elongation, there are two forces accelerating the bob:
Gravitational force and electrostatic force.
There is one force deaccelerating it :
Spring Force
A max elongation means a point where the forces are balanced and the velocity of the bob equals 0
Would there be a point in time where the spring force becomes more than the downward force?
because I believe thats whats needed to make the velocity equal to 0 and then eventually the velocity vector would point in the upward direction
Spring Force
Yes
No. Think about the simple case of a ball thrown straight up in the air. At the highest point, v = 0. But, is the net force on the ball zero at this instant?
Yes. That's right.
Hint: Energy rather than force is your friend here.
Likes tellmesomething
TSny said:
Yes
Yes. That's right.
Okay got it. Thankyou :-)
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
