Force and Air Balloon problem help
In summary, the question is asking what fraction of the total weight of a hot-air balloon, consisting of a basket, one passenger, and some cargo, must be dropped overboard in order for the balloon to accelerate upward at a rate of g/2. The balloon is initially accelerating downward at a rate of g/3 and the upward lift force remains constant at 2Mg/3. Using the equation F=ma, the solution involves setting the net force equal to the mass times the acceleration, and then solving for the fraction of weight that must be dropped overboard.
Kinermatics
A hot-air balloon consists of a basket, one passenger, and some cargo. Let the total mass be M. Even though there is an upward lift force on the balloon, the balloon is initially accelerating downward at a rate of g/3.
The passenger notices that he is heading straight for a waterfall and decides he needs to go up. What fraction of the total weight must he drop overboard so that the balloon accelerates upward at a rate of g/2? Assume that the upward lift force remains the same.
Lift Force = 2Mg/3
F = ma
I basically just tried to divide 2Mg/3 with g/2. But I just got M(4/3). The answer is 5/9. What critical information am I missing?
Lift Force = 2Mg/3
F = ma
To start, apply that equation to the situation where the balloon is accelerating downward at g/3. What do you get? (You might need to think carefully about what the F means in F=ma.)
Related to Force and Air Balloon problem help
1. What is a force and air balloon problem?
A force and air balloon problem is a physics problem that involves calculating the forces acting on a hot air balloon in order to determine its motion and stability.
2. How do you calculate the forces acting on a hot air balloon?
The forces acting on a hot air balloon can be calculated using Newton's laws of motion. The weight of the balloon, the buoyant force from the surrounding air, and the force of the wind are all considered when determining the net force on the balloon.
3. What factors affect the motion and stability of a hot air balloon?
The motion and stability of a hot air balloon can be affected by a number of factors, including the weight of the balloon, the temperature of the air inside the balloon, the buoyancy of the surrounding air, and the direction and strength of the wind.
4. How does the temperature of the air inside the balloon affect its motion and stability?
The temperature of the air inside the balloon affects its motion and stability because it directly impacts the density of the air. As the temperature of the air inside the balloon increases, its density decreases, making the balloon more buoyant and causing it to rise. On the other hand, if the air inside the balloon cools, it becomes more dense and the balloon will descend.
5. What is the importance of calculating the forces on a hot air balloon?
Calculating the forces on a hot air balloon is important because it allows us to understand and predict the behavior of the balloon. By knowing the forces acting on the balloon, we can determine its direction and speed of motion, as well as its stability in different conditions. This information is crucial for safe and successful hot air balloon flights.
