Force and motion -- Person falling from 20m onto a cushion (EASY)
In summary, both methods are wrong because they assume constant acceleration after meeting the cushion. A spring would be a better model.
guest948
A cushion is 3m high when inflated. Assume a person of mass 50kg falls onto the cushion from 20m above the ground and is brought to a stop in 0.25s after hitting the cushion. Assume air resistance is negligible.
How high is the person from the ground when he is stopped by the cushion? Assume that he decelerates uniformly.
TASK: Please help explain why approach 2 is INCORRECT.
The following have been confirmed:
- The person's velocity just before he hits the cushion is 18.263 ms-1 (downwards).
- The average net force acting on the person during the impact is 3652.62 N (upwards).
s = (v+u)/2 * t
PE = mgh
KE = mv^2/2
Ft = mv - mu
APPROACH 1 (correct):
Height above ground = 3 - (v+u)/2 * t
= 3 - 18.263/2 * 0.25
= 0.717 m
APPROACH 2 (incorrect):
Let d be the height from the ground when he is stopped by the cushion.
PE loss = Work done against motion by cushion
mgh = Fs
mg(20-d) = F(3-d)
50 * 9.81 * (20-d) = 3652.62 * (3-d)
d = 0.363 m
guest948 said:
Homework Statement:: A cushion is 3m high when inflated. Assume a person of mass 50kg falls onto the cushion from 20m above the ground and is brought to a stop in 0.25s after hitting the cushion. Assume air resistance is negligible.
Relevant Equations:: s = (v+u)/2 * t
PE = mgh
KE = mv^2/2
Ft = mv - mu
= 0.717 m
mgh = Fs
mg(20-d) = F(3-d)
d = 0.363 m
Both methods are wrong since they assume constant acceleration after meeting the cushion. That might be right for a snowpack, but not for an inflated cushion. A spring would be a better model.
In your second method, on the left of the equation you have the work done by gravity over the whole descent. On the right, you have the work done by the net force (which includes gravity) in the last 3-d of the descent. So you are counting the work done by gravity in the last 3-d on both sides.
See what happens if you change the 20-d to 17.
Thanks, but constant acceleration (deceleration) is assumed in this question.
Ok, so see my edit to post #2.
Likes guest948
Related to Force and motion -- Person falling from 20m onto a cushion (EASY)
1. How does the force of gravity affect a person falling from 20m onto a cushion?
The force of gravity is the main force acting on the person as they fall. It causes the person to accelerate towards the ground at a rate of 9.8 meters per second squared.
2. What is the relationship between force and motion in this scenario?
The force of gravity causes the person to accelerate towards the ground, resulting in motion. As the person falls, their velocity increases due to the constant force of gravity acting on them.
3. How does the cushion affect the person's fall?
The cushion acts as a force opposing the person's fall. When the person lands on the cushion, it compresses and absorbs some of the force of the impact, slowing down the person's descent and reducing the risk of injury.
4. What is the force of impact on the person when they land on the cushion?
The force of impact on the person depends on various factors such as the person's mass, the height of the fall, and the type of cushion. However, the cushion reduces the force of impact by spreading it out over a larger area, making it less harmful to the person.
5. How does the person's position affect the force and motion during the fall?
The person's position can affect the force and motion during the fall. For example, if the person is falling feet first, they will experience a greater force of impact on their feet compared to if they were falling on their back. This can also affect the way the cushion absorbs the impact and the risk of injury to different parts of the body.
