gobbles
- 17
- 1
Consider two solid dielectric spheres of radius ##a## separated by a dis-
tance ##R## (##R\gg a##).
One of the spheres has a charge ##q## and the other is
neutral. We scale up the linear dimensions of the
system by a factor of two. How much charge should reside on the first
sphere now so that the force between the spheres remains the same?
See below.
I know that the neutral sphere becomes a dipole and then it's a problem of the force on a dipole in an electric field and that the correct answer is ##4\sqrt{2} q##, but I tried a different approach:
We know that a surface charge ##\sigma## is formed on the surface of the neutral sphere, affected by the charged sphere. This surface charge depends on the distance ##R## between the spheres, the radius ##a## of the spheres and the charge ##q## on the charged sphere, and also has some angular dependence (assuming that the origin of axes is in the center of the neutral sphere and the angle (##\theta##) is taken from the horizontal axis).
The dependence of ##\sigma## on the said parameters must be of the form ##qa^{-\alpha} R^{\alpha-2}\Theta(\theta)##, because the units must be charge over area and ##\Theta(\theta)## is some angular dependence.
Additionally, the force acting on a surface element ##da## of the neutral sphere is ##\frac{q\sigma da}{\left(R(\theta)\right)^2}##, where ##R(\theta)## is the distance from the center of the charged sphere to the surface element of the neutral sphere
Now we can write an expression for the force acting on the neutral sphere (##A## is the surface of the neutral sphere):
F=\int_{\mbox{A}} \frac{q\sigma da}{\left(R(\theta)\right)^2}=\int \frac{q a^2 d\Omega}{\left(R(\theta)\right)^2}qa^{-\alpha} R^{\alpha-2}\Theta(\theta)\\
=\int \frac{q^2 a^2 d\Omega}{R^2 + a^2 + 2Ra\cos\theta}a^{-\alpha} R^{\alpha-2}\Theta(\theta)=\int \frac{q^2 R^{\alpha-2}a^{2-\alpha} d\Omega}{R^2 + a^2 + 2Ra\cos\theta} \Theta(\theta)\\
\approx q^2\left(\frac{a}{R}\right)^{2-\alpha}\frac{1}{R^2}\int d\Omega\Theta(\theta)(1-2\cos\theta \frac{a}{r}).
If we take the first term, we get
##F\propto q^2\frac{a^{2-\alpha}}{R^{4-\alpha}}##.
If we increase the distances ##a## and ##R## by 2, we get:
##q^2\frac{a^{2-\alpha}}{R^{4-\alpha}}=Q^2\frac{a^{2-\alpha}}{R^{4-\alpha}}\frac{2^{2-\alpha}}{2^{4-\alpha}}=Q^2\frac{a^{2-\alpha}}{R^{4-\alpha}}\frac{1}{4},##
So we get ##Q=2q,##, unlike the true answer ##Q=4\sqrt{2} q##.
What am I missing?
