Force between charges with two dielectric media
In summary, the conversation discusses the force between two charges in the presence of two dielectric media separated by a plane at z=0. The solution uses image charges to match the boundary conditions at the dielectric boundary, and the force on each charge is determined by the product of the charge and electric field intensity at the charge location. However, in the case where the charges are on the same side of the boundary, the forces are not equal and opposite as expected and there is a net force towards or away from the boundary. The equivalent permitivity, which is not a function of the distances of the charges from the boundary, is also a concern. The conversation also mentions the use of a simplified version of the method of images found in a
JerryR
Does anyone have a formula and derivation of the force between two charges in the presence of two dielectric media. Specifically, have the two dielectric media separated by a plane at z = 0. I have a developed a solution using image charges to matched the boundary conditions at the dielectric boundary. The force on each charge is then determined by the product of the charge and electric field intensity at the charge location. However, the answer I get does not make physical sense.
In the case where the charges are on opposite sides of the boundary the forces are equal and opposite as expected. The permitivity is replaced by an equivalent permitivity of E = 2*E1*E2/(E1+E2). My concern is that the equivalent permitivity is not a function of the distances of the charges from the boundary.
In the case where the charges are on the same side things get even more weird. As the electric field is not directly toward the charges the forces are not equal and opposite. There is a net force toward or away from the boundary depending on the relative magnitude of the permitivities.
I am having problems creating a simulation of a much more complex structure. However, I traced the problem to this fundamental question. Could anyone point me to a solution to this?
Thanks
I am guessing that the "plane" is a conductor (what thickness?) for the method of images to be appropriate.
Is that correct?
I think you need to be more explicit about the setup; i.e. are the charges in question equal? Do they both lie on the z axis?
I'm guessing an orientation so that the "plane" of unspecified properties is in the x-y plane... but you have not said, only that it passes through z=0.
If the charges are on the same side of the plane - then the method of images gives two extra effective charges right?
If may be useful to understand what is happening by using another method.
I will try for a more full explanation and show the analysis. As you expeceted the interface between the dielectrics is in the x-y plane. z=0 at all points on the interface. There is no conductor at the interface. For the image charges I have used a simplified version of the methods found in T. Takashima and R. Ishibashi, "Electric Fields in Dielectric Multi-Layers Calculated by Digital Computer," IEEE Transactions Electrical Insulation, Vol EI-13, No. 1, February 1978. This paper addresses multiple parallel dielectric boundaries and a ground plane. In my case I have only one dielectric.
Let the space above the interface (##z>0##) have permitivity ##\epsilon_1## and that below the interface have permitivity ##\epsilon_2##. Let charge ##Q_1## be located at (x,y,x) = (0,0,a). The fields in the upper dielectric may be determined by the use of an image charge of magnitude ##\alpha_{12} Q_1## at location (0,0,-a) where ##\alpha_{12} = \frac{\epsilon_1 - \epsilon_2}{\epsilon_1 + \epsilon_2}##. The electric field (##E_1##) in the upper dielectric will the vector sum of the fields from ##Q_1 ## and ## \alpha_{12} Q_1## treated as if both of these charges were in a medium with permitivity ##\epsilon_1##. Note that as ##\epsilon_2 \rightarrow \infty## the boundary becomes a ground plane, ##\alpha_{12} \rightarrow -1## and the image charge becomes ##-Q_1## as expected for a ground plane.
The electric field in the lower dielectric may be determined by the use of an image charge of magnitude ##\beta_{12} Q_1## located at (0,0,a) where ##\beta_{12} = \frac{2 \epsilon_2}{\epsilon_1 + \epsilon_2}##. In this region the electric field (##E_2##) is a result of only one charge treated as though it were in a medium of permitivity ##\epsilon_2##.
When these resulting electric fields are evaluated at z=0 the necessary boundary conditions are met. The tangential components of the fields match as ##E_{t1} =E_{t2}##. The normal components match as ##\epsilon_1 E_{n1} = \epsilon_2 E_{n2}##.
The force on a second charge may be determined by the static portion of the Lorentz force equation. In this case ##\mathbf{F} = Q_2 \mathbf{E}##. If the second charge is in the lower medium the electric field is directed to the location of the first charge. Working through the fields from the charges gives a force magnitude of ##F = \frac{Q_1 Q_2}{4 \pi \epsilon' r^2}## where ##r## if the distance between the charges and ##\epsilon' = \frac{2 \epsilon_1 \epsilon_2}{\epsilon_1+\epsilon_2}##. The force the second charge exerts on the first charge may be determined by the same analysis exchanging the subscripts. The forces on the charges are equal and directed toward or away from the charge location depending on the sign of the charges.
If the second charge is located in the upper medium along with the first charge then the situation is more complex. As the electric field is the result of two charges (##Q_1## and ## \alpha_{12} Q_1##) the field cannot be directed at ##Q_1##. Therefore, the force has a component toward or away from the interface depending on the charge signs and the relative magnitude of the permitivities. This is the part that bothers me. There appears to be a force with no counter force. If this were to be true I could come up with a device to violate conservation of energy. This is clearly not real.
I would appreciate any help in showing where the flaw is in my analysis. I hope that this is readable. Perhaps due to the length of the post the preview is not working and I hope that the LaTeX is correct.
Thanks
Related to Force between charges with two dielectric media
1. What is the force between two charges with two dielectric media?
The force between two charges with two dielectric media is the attractive or repulsive force that exists between two charged particles when they are separated by a medium with different dielectric constants. This force is a result of the interaction between the electric fields of the two charges and the dielectric medium.
2. How does the dielectric constant affect the force between two charges?
The dielectric constant, also known as the relative permittivity, is a measure of how well a material can store electrical energy. In the context of the force between two charges with dielectric media, a higher dielectric constant indicates a stronger electric field within the material, resulting in a stronger force between the charges.
3. What is the equation for calculating the force between two charges with two dielectric media?
The equation for calculating the force between two charges with two dielectric media is given by Coulomb's law, modified to incorporate the dielectric constants of the two media. It is represented as F = (1/4πε0εr1εr2) * (q1q2/r2), where ε0 is the permittivity of free space, εr1 and εr2 are the dielectric constants of the two media, q1 and q2 are the charges of the particles, and r is the distance between them.
4. Can the force between two charges with dielectric media be attractive and repulsive at the same time?
Yes, the force between two charges can be both attractive and repulsive at the same time when the two charges have opposite signs and are separated by a medium with a varying dielectric constant. In this case, the force between the charges will be attractive in some regions of the medium and repulsive in others, depending on the dielectric constants at those points.
5. How does the distance between two charges affect the force with dielectric media?
The force between two charges with dielectric media is inversely proportional to the square of the distance between the charges. This means that as the distance between the charges increases, the force between them decreases. This relationship is similar to the force between two charges in vacuum, but it is modified by the presence of the dielectric media.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
