Force between two aligned permanent dipoles
In summary, the conversation discusses deriving the attractive force between two aligned permanent dipoles, which varies as r^{-4}. The electric field on the axis of a dipole is derived using Taylor's expansion and the potentials of the two charges.
overmage
Show that the force between two aligned permanent dipoles, a distance r apart, is attractive and varies as [tex]r^{-4}[/tex]
Length of dipole to be taken as d.
None provided.
I'm completely lost here and have no idea where to begin. My attempts at a solution have only led me to discover that somehow, energy of the dipole between two charged molecules is supposed to be E=[tex]\frac{p}{4\pi\epsilon_{0}r^{3}}[/tex] (where p = dipole moment = qd)
As to why this is so, I have no idea!
I've searched around these forums for similar problems. What is the electric field of a dipole and how do I derive it? I read that it's something to do with Taylor's Expansion on d/r. I realize I may sound like an idiot for asking such elementary questions, so i apologize.
What do you mean by aligned? aligned how?
Also, that's not an energy you've written down, looks like the electric field to me! :D
The electric field **on axis** of a dipole is not too difficult to derive. (Off axis involves vectors and becomes more complicated) Assume the two charges that make up the dipole (+q and -q) lie on the z axis. Let +q lie at position z, and -q lie at position z+d.
You know what the potential due to a point charge is? You know that the potentials of the two charges will add? You can use a taylor approximation on the 1/(z+d) term to simplify the total potential. Then the electric field will be given by gradient of the total potential.
FAQ: Force between two aligned permanent dipoles
What is the force between two aligned permanent dipoles?
The force between two aligned permanent dipoles is known as the dipole-dipole interaction force. It is an electrostatic force that exists between two electric dipoles, which are molecules or atoms with a separation of positive and negative charges.
How is the force between two aligned permanent dipoles calculated?
The force between two aligned permanent dipoles can be calculated using Coulomb's law, which states that the force is directly proportional to the product of the magnitudes of the charges and inversely proportional to the square of the distance between them.
What factors affect the strength of the force between two aligned permanent dipoles?
The strength of the force between two aligned permanent dipoles is affected by the magnitude of the charges on the dipoles, the distance between them, and the orientation of the dipoles relative to each other.
Can the force between two aligned permanent dipoles be attractive or repulsive?
The force between two aligned permanent dipoles can be either attractive or repulsive, depending on the orientation of the dipoles. If the dipoles are aligned in the same direction, the force will be attractive. If they are aligned in opposite directions, the force will be repulsive.
How does the force between two aligned permanent dipoles affect the properties of materials?
The force between two aligned permanent dipoles plays a crucial role in determining the properties of materials. It is responsible for the formation of hydrogen bonds, which contribute to the strength and stability of many materials. It also affects the dielectric properties of materials, such as their ability to conduct electricity.
